Choker Necklace Jump Ring Replacement
  1. Choker Necklace Jump Ring Replacement, Jump Ring: step 1, image 1 of 1
    • The materials include: two long-nose pliers, a jump ring, and the necklace you are repairing.
    Ask FixBot
  2. Choker Necklace Jump Ring Replacement: step 2, image 1 of 2 Choker Necklace Jump Ring Replacement: step 2, image 2 of 2
    • Grab the jump ring at the opposite side of the slit with your fingers (or long-nose pliers if the jump ring is too small to handle). Then, with your other hand (or long-nose pliers), grab the clasp at the end that's opposite of the loop ring hole.
    Ask FixBot
  3. Choker Necklace Jump Ring Replacement: step 3, image 1 of 1
    • Thread the loop ring through the tiny hole that's protruding from the bottom of the clasp. Continue to hold onto the loop ring without letting the clasp fall off and remove the opposite hand/tool's hold on the clasp.
    Ask FixBot
  4. Choker Necklace Jump Ring Replacement: step 4, image 1 of 2 Choker Necklace Jump Ring Replacement: step 4, image 2 of 2
    • Without releasing the hold on the loop ring and clasp, use the opposite hand to grab the end of the necklace that doesn't have the long chain attached to it. Carefully place the necklace end on the loop ring and release, allowing the loop ring to thread through it without having to move the loop ring.
    Ask FixBot
  5. Choker Necklace Jump Ring Replacement: step 5, image 1 of 2 Choker Necklace Jump Ring Replacement: step 5, image 2 of 2
    • Going from the sides, use the long-nose pliers to slowly and gently pinch close the loop ring as seen in the picture. Loop ring may break If done with too much pressure.
    Ask FixBot
  6. Choker Necklace Jump Ring Replacement: step 6, image 1 of 2 Choker Necklace Jump Ring Replacement: step 6, image 2 of 2
    • Going from the top, squeeze the jump ring together using the long-nose pliers. This will keep the loop ring from opening back up without having to solder it.
    Ask FixBot
  7. Choker Necklace Jump Ring Replacement: step 7, image 1 of 1
    • Once the jump ring is closed, secure the clasp on the other end of the choker.
    Ask FixBot
  8. Choker Necklace Jump Ring Replacement: step 8, image 1 of 1
    • The repair is finished.
    Ask FixBot
Now that the jump ring is secured, the fixed necklace can now be worn.
Katherine Gemmingen
187 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 60
All Time: 1,153
