Chevy 305 Engine Oil Pump Replacement
Views: 5K
View statistics:
Past 24 Hours:
2
Past 7 Days:
24
Past 30 Days:
132
All Time:
5,002
Comments: 1
1 comment on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 - 2 hours
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide is intended for use on engines already removed from the vehicle. While this kind of work may be possible to complete with the engine still in the car, it will be much easier with the engine removed.
The oil pump serves the purpose of generating the oil pressure needed in order to circulate oil through the car. Without a properly performing oil pump you will not have a successful running engine.
    1. Chevy 305 Engine Oil Pump Replacement, Oil pump: step 1, image 1 of 2 Chevy 305 Engine Oil Pump Replacement, Oil pump: step 1, image 2 of 2
      • Remove the 18 bolts holding the oil pan in place using the 3⁄8 and 1⁄2 sockets, 6 inch extension and 3⁄8 ratchet.
      • Fourteen 3/8 bolts around the perimeter and four 1/2 bolts on each corner
      • Lift the oil pan up and forward so the oil pump pick up will clear the baffle.
      • Do not remove the oil pan gasket yet.
      Ask FixBot
    2. Chevy 305 Engine Oil Pump Replacement: step 2, image 1 of 2 Chevy 305 Engine Oil Pump Replacement: step 2, image 2 of 2
      • Remove the single 9/16 bolt holding the oil pump in place.
      • Using a rubber mallet to break loose, gently tap on the side of the base of the pump indicated by the arrow. DO NOT HIT THE TOP OF THE PICK UP TUBE AND SCREEN. This can potentially damage the pick up tube or screen.
      Ask FixBot
    3. Chevy 305 Engine Oil Pump Replacement: step 3, image 1 of 1
      • Pull straight up from the base of the oil pump to remove.
      • Replace with a new oil pump.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Torque oil pump bolt to 60-70ft.-lbs. Torque oil pan bolts to 12ft.-lbs.
2 other people completed this guide.
Joey Barton
460 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 24
Past 30 Days: 132
All Time: 5,002
