Chevy 305 Engine Connecting Rod Bearing Replacement
Views: 4.4K
View statistics:
Past 24 Hours:
3
Past 7 Days:
24
Past 30 Days:
122
All Time:
4,366
Comments: 0
Go to guide comments
Completed: 8
8 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 - 2 hours
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide is intended for use on engines already removed from the vehicle. While this kind of work may be possible to complete with the engine still in the car, it will be much easier with the engine removed.
The connecting rod is what connects the piston with the crankshaft on an engine. It converts the “push-pull” motion of the piston to the rotational motion of the crankshaft hence needing some sort of bearing in order for the circular motion to be performed smoothly.
    1. Chevy 305 Engine Connecting Rod Bearing Replacement, Connecting Rod Bearing: step 1, image 1 of 2 Chevy 305 Engine Connecting Rod Bearing Replacement, Connecting Rod Bearing: step 1, image 2 of 2
      • Remove the 18 bolts holding the oil pan in place using the 3⁄8 and 1⁄2 sockets, 6 inch extension and 3⁄8 ratchet.
      • Fourteen 3/8 bolts around the perimeter and four 1/2 bolts on each corner
      • Lift the oil pan up and forward so the oil pump pick up will clear the baffle.
      • Do not remove the oil pan gasket yet.
      Ask FixBot
    2. Chevy 305 Engine Connecting Rod Bearing Replacement: step 2, image 1 of 1
      • Remove the two 5/8 nuts on the connecting rod end cap using the 5/8 socket
      • Gently tap the side of the cap with a rubber mallet if needed to break free.
      Ask FixBot
    3. Chevy 305 Engine Connecting Rod Bearing Replacement: step 3, image 1 of 1
      • Remove and replace connecting rod bearing
      • Gently tap the end cap against the engine block or use a thin flathead screwdriver to remove it from the end cap.
      • Gently move the piston and rod down into the cylinder to replace the rod end bearing.
      • DO NOT PUSH THE PISTON OUT OF THE CYLINDER.
      Ask FixBot
    4. Chevy 305 Engine Connecting Rod Bearing Replacement: step 4, image 1 of 1
      • Liberally apply assembly lubricant/oil to the new bearing surfaces and crankshaft journal.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Torque the connecting rod cap nuts to 65ft.-lbs. Torque the oil pan bolts to 12ft.-lbs.
8 other people completed this guide.
Joey Barton
460 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 122
All Time: 4,366
