Chevrolet Windshield Wiper Motor / Transmission Replacement
Views: 9.6K
View statistics:
Past 24 Hours:
4
Past 7 Days:
53
Past 30 Days:
182
All Time:
9,558
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 - 45 minutes
Difficulty: Moderate
Needs More Images
A few more images would make this guide's procedures crystal clear.
Community-Contributed Guide
Introduction
Go to step 1 ↓
Remove and replace the windshield wiper transmission assembly which includes the wiper motor
      • Raise the hood.
      • Remove the negative terminal clamp from the battery. Should be 10 mm
      Ask FixBot
      • Apply painters tape to the windshield under each wiper arm.
      • Use a mark to record the wiper arm position on the windshield
      Ask FixBot
      • Remove Antenna, use the proper wrench to loosen the antenna from the base.
      • Pull the washer hoses off of the small studs near the wiper arm bases.
      • Open the plastic caps from the base of the washer arms, using the proper socket wrench, loosen and remove the hold down nut.
      • Remove the washer arms. They make a puller tool but you should be able to wiggle them back and forth and lift them off the stud.
      Ask FixBot
      • Remove the plastic end covers by prying them off with a wide screw driver
      • Remove 2 clips on the front of the plastic grille.
      • Remove 2 bolts from each side of the plastic grille.
      • Pull up on the grille and disconnect the wiper fluid tube near the drivers fender. there should be a section that will pull apart to allow removal.
      Ask FixBot
      • remove three bolts holding the wiper transmission to the body. There should be a rubber gasket on each one - do not remove them from the assembly.
      • Remove the power plug, squeeze the plug on the bottom and pull, it should release with little effort.
      • Now you have to wiggle the transmission back and forth in the fire wall area in order to get it out
      Ask FixBot
      • Using a screwdriver, pry off the linkage from the motor arm.
      • Remove three TORX (30) screws which will separate the wiper motor from the wiper transmission.
      • NOTE - if you purchase the wiper transmission assembly from a Chevy dealership, it will probably come with a new motor already attached. This means you can skip this step.
      Ask FixBot
      • Reverse the steps to install the wiper transmission assembly.
      Ask FixBot
Greg
163 Reputation
1 Guide authored
1 Guide Comment
Linkage does not move
david carrizales - Reply Share
Past 24 Hours: 4
Past 7 Days: 53
Past 30 Days: 182
All Time: 9,558
