Cherry Stream 3.0 Key Replacement
  1. Cherry Stream 3.0 Key Replacement, Key: step 1, image 1 of 1
    • That's how the problematic thing looks like.
  2. Cherry Stream 3.0 Key Replacement: step 2, image 1 of 1
    • First insert the top edge.
  3. Cherry Stream 3.0 Key Replacement: step 3, image 1 of 1
    • Simple release the plastic.
  4. Cherry Stream 3.0 Key Replacement: step 4, image 1 of 1
    • Press the bottom edge down, to insert it at the bottom.
  5. Cherry Stream 3.0 Key Replacement: step 5, image 1 of 1
    • To insert the key just squeeze it from above.
Finish Line
8 other people completed this guide.
Albertere Zweitausend
562 Reputation
3 Guides authored
4 Guide Comments
Bei den Kleinen Tasten ging es ohne Probleme. Leider habe ich ein Problem mit der STRG Taste und der Windows Taste wie wird es dort korrekt gemacht?
Tobiii As - Reply Share
Ich habe das gleiche Problem. Haben Sie es schon geschafft?
hansmeisner - Share
i had the same question and just figured it out. the larger keys like winodws and ALT have additionally a metal bar. you go as explained in step 1-4. Then first attach the metal bar to the key. Then push the key in its dedicated position. Worked for me
Jens Schäfer - Reply Share
I managed to get the two parts of the scissor disconnected while removing the CAPS key to remove a tiny screw that fell into the keyboard. I worked out how they had to go together again... eventually. It's also easier to reattach the metal bar to the key if you take it off the board.
Oooops! - Reply Share
Past 24 Hours: 23
Past 7 Days: 168
Past 30 Days: 772
All Time: 29,778
