Up to 20% off select tools
Chefmate TO-09 Timer Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
18
Past 30 Days:
94
All Time:
1,135
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Easy
Parts
Tools
Introduction
Go to step 1 ↓
If the timer on your Chefmate Toaster Oven (model TO-09) has stopped functioning, use this guide to learn how its function can be replaced or restored.
The timer on the toaster oven sets the duration of time for which the appliance will be actively heating. A defective timer switch will not turn off the oven at the end of the time selected, or it may cease the function of the appliance completely by not being able to start the oven in the first place.
Before using this guide, inspect the exterior of the timer to make sure nothing is obstructing its mobility. The timer function should typically still work regardless of whether it is plugged into power or not. If after inspection it still is not working, we can conclude that the timer is dysfunctional.
Steps 2 and 3 require the use of the Phillips #0 Screwdriver, or a “plus” screwdriver that has a head with pointed edges in the shape of a cross or plus sign. In addition, a flat screwdriver is needed to complete step 5, and flat pliers may also be needed to complete the step.
Before beginning, make sure the appliance is completely unplugged from power.
    1. Chefmate TO-09 Timer Replacement, Chefmate TO-09 Timer Replacement: step 1, image 1 of 3 Chefmate TO-09 Timer Replacement, Chefmate TO-09 Timer Replacement: step 1, image 2 of 3 Chefmate TO-09 Timer Replacement, Chefmate TO-09 Timer Replacement: step 1, image 3 of 3
      • Examine the condition of the appliance.
      • Remove the tray from inside the toaster oven before dissembling.
      • With the tray removed, this is a great opportunity to clean your toaster oven . Built up debris left over time could lead to functional issues in the future!
      Ask FixBot
    2. Chefmate TO-09 Timer Replacement: step 2, image 1 of 3 Chefmate TO-09 Timer Replacement: step 2, image 2 of 3 Chefmate TO-09 Timer Replacement: step 2, image 3 of 3
      • Flip the toaster oven on its head so that its bottom side is facing upwards.
      • Use a Phillips #0 screwdriver to remove the four screws hidden underneath the legs of the appliance.
      • There are two legs covering the two screws in the front peg .
      • The other two screws are visible under the back legs.
      Ask FixBot
    3. Chefmate TO-09 Timer Replacement: step 3, image 1 of 3 Chefmate TO-09 Timer Replacement: step 3, image 2 of 3 Chefmate TO-09 Timer Replacement: step 3, image 3 of 3
      • Return the toaster oven to its upright position and rotate it so its backside is facing you.
      • Use the Phillips #0 screwdriver to unscrew the four screws visible on the backside.
      • Keep track of loose screws for later re-assembly.
      Ask FixBot
    4. Chefmate TO-09 Timer Replacement: step 4, image 1 of 3 Chefmate TO-09 Timer Replacement: step 4, image 2 of 3 Chefmate TO-09 Timer Replacement: step 4, image 3 of 3
      • With the appliance facing you, remove the top cover of the toaster oven to access the timer location.
      Ask FixBot
    5. Chefmate TO-09 Timer Replacement: step 5, image 1 of 3 Chefmate TO-09 Timer Replacement: step 5, image 2 of 3 Chefmate TO-09 Timer Replacement: step 5, image 3 of 3
      • Use the flat screwdriver as a wedge and pop the timer knob out of place.
      • If you have difficulty removing the timer by hand, use a flat plier to pry off the timer knob.
      Ask FixBot
    6. Chefmate TO-09 Timer Replacement: step 6, image 1 of 3 Chefmate TO-09 Timer Replacement: step 6, image 2 of 3 Chefmate TO-09 Timer Replacement: step 6, image 3 of 3
      • With the timer in hand, gently remove the two wires attached to the square object.
      • Unplug the timer wire gently, or else this may cause damage to the cables.
      Ask FixBot
    7. Chefmate TO-09 Timer Replacement: step 7, image 1 of 3 Chefmate TO-09 Timer Replacement: step 7, image 2 of 3 Chefmate TO-09 Timer Replacement: step 7, image 3 of 3
      • Before replacing your timer with a new one, you may try to lubricate it first to see if it fixes the issue.
      • Apply WD-40 to the timer's slight peek edge.
      • Let the WD-40 sit and take effect for around 30 seconds or a minute after you spray it onto the timer.
      • The WD-40's oil will seep inside the timer, reaching the tiny gear of the timer.
      • WD-40 is flammable. Be sure to read the instruction label before using WD-40 Two-Way Spray Can.
      • Not cleaning/wiping off excess WD-40 oil on the timer will start a fire in the toaster oven.
      • You can test the timer using a flat head screwdriver to turn the timer to see if it ticks/works.
      Ask FixBot
Author
with
Andy Tran
172 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 94
All Time: 1,135
