Chefman RJ38-V2-35 Power Cord Replacement
    1. Chefman RJ38-V2-35 Power Cord Replacement, Power Cord: step 1, image 1 of 1
      • Please be sure that the device is unplugged and remove the frying basket from the device.
      • Check the power cord for frays or cracks
      Ask FixBot
    2. Chefman RJ38-V2-35 Power Cord Replacement: step 2, image 1 of 2 Chefman RJ38-V2-35 Power Cord Replacement: step 2, image 2 of 2
      • If the cord appears to be fine, orient your device upside down so that the temperature knob is on the bottom and the power cord area is facing you.
      • Place your hand firmly on the device to prevent slippage.
      • Using the Phillips #1 screwdriver, remove the two 4 mm screws found at each corner of the bottom panel.
      Ask FixBot
    3. Chefman RJ38-V2-35 Power Cord Replacement: step 3, image 1 of 2 Chefman RJ38-V2-35 Power Cord Replacement: step 3, image 2 of 2
      • After removing the two screws on the bottom, remove the four 6mm screws located on the white tabs that are securing the power cord.
      • Once the white tabs come off, the power cord will be more visible, the white wire is connected with the blue wire, while the black wire is connected with the red wire.
      Ask FixBot
    4. Chefman RJ38-V2-35 Power Cord Replacement: step 4, image 1 of 2 Chefman RJ38-V2-35 Power Cord Replacement: step 4, image 2 of 2
      • Use a pair of scissor, cut off any secure wire attachments, such as the white capsule.
      • The wire will come apart and you can now separate the power cord from the device’s wires.
      • The red and blue wires of the device will show it’s aluminum strips, this is what connect to the replacement wire.
      Ask FixBot
5 other people completed this guide.
An L Duong
349 Reputation
1 Guide authored
UW Tacoma, Team S1-G4, Rose Fall 2018 Member of UW Tacoma, Team S1-G4, Rose Fall 2018
UWT-ROSE-F18S1G4
4 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 70
All Time: 8,915
