Chef's Choice M115 Power Cord Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
14
Past 30 Days:
70
All Time:
1,097
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Power cords on appliances such as this can get damaged easily. Instead of throwing it out, consider replacing the cord. As with any other electrical device, a damaged power cord can cause a fire or injury, so this guide can assist in reducing that risk.
    1. Chef's Choice M115 Power Cord Replacement, Case: step 1, image 1 of 2 Chef's Choice M115 Power Cord Replacement, Case: step 1, image 2 of 2
      • Remove the two rubber feet on the motor side of the device.
      • Remove the five Phillips screws from the bottom of the case.
      • These screws are recessed deep in the device, so a long, thin screwdriver is required.
      Ask FixBot
    2. Chef's Choice M115 Power Cord Replacement: step 2, image 1 of 1
      • Remove the two hex-cap screws on the bottom using a pair of pliers.
      Ask FixBot
    3. Chef's Choice M115 Power Cord Replacement: step 3, image 1 of 1
      • Carefully flip the device right-side-up while grasping the top and bottom pieces.
      • The white cover should lift off with no resistance. If it does not, ensure all screws were removed in previous step.
      Ask FixBot
    4. Chef's Choice M115 Power Cord Replacement: step 4, image 1 of 1
      • Remove the sharpener guard by gently pulling up on it.
      • If the sharpener guard does not come off easily, ensure all screws were removed in step 1.
      Ask FixBot
    1. Chef's Choice M115 Power Cord Replacement, Power Cord: step 5, image 1 of 2 Chef's Choice M115 Power Cord Replacement, Power Cord: step 5, image 2 of 2
      • Carefully lift the entire motor assembly out of the case.
      Ask FixBot
    2. Chef's Choice M115 Power Cord Replacement: step 6, image 1 of 1
      • Remove the spade connectors from the switch by pulling only on the connector, not the wire.
      • These should come off without tools, but will require a fair bit of force. Mark each wire with tape if you are unsure of the wiring layout of the device.
      Ask FixBot
    3. Chef's Choice M115 Power Cord Replacement: step 7, image 1 of 1
      • Disconnect the spade connector on the motor by pulling only on the connector, not the cord.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take care to ensure the power connections are connected back to their original location.
Zachary Grounds
592 Reputation
3 Guides authored
IUPUI, Team 3-3, Harley Fall 2015 Member of IUPUI, Team 3-3, Harley Fall 2015
IUPUI-HARLEY-F15S3G3
5 Members
72 Guides authored
1 Guide Comment
I cannot find a replacement cord with the molded part that passes through the case. Is this something common (from hardware store), or do I need to find a part from the manufacturer?
Luke Shingledecker - Reply Share
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 70
All Time: 1,097
