Chef's Choice M115 Linkage Pins Replacement
  1. Chef's Choice M115 Linkage Pins Replacement, Case: step 1, image 1 of 2 Chef's Choice M115 Linkage Pins Replacement, Case: step 1, image 2 of 2
    • Remove the two rubber feet on the motor side of the device.
    • Remove the five Phillips screws from the bottom of the case.
    • These screws are recessed deep in the device, so a long, thin screwdriver is required.
    Ask FixBot
  2. Chef's Choice M115 Linkage Pins Replacement: step 2, image 1 of 1
    • Remove the two hex-cap screws on the bottom using a pair of pliers.
    Ask FixBot
  3. Chef's Choice M115 Linkage Pins Replacement: step 3, image 1 of 1
    • Carefully flip the device right-side-up while grasping the top and bottom pieces.
    • The white cover should lift off with no resistance. If it does not, ensure all screws were removed in previous step.
    Ask FixBot
  4. Chef's Choice M115 Linkage Pins Replacement: step 4, image 1 of 1
    • Remove the sharpener guard by gently pulling up on it.
    • If the sharpener guard does not come off easily, ensure all screws were removed in step 1.
    Ask FixBot
  5. Chef's Choice M115 Linkage Pins Replacement, Grinding Disc Linkage Pins: step 5, image 1 of 1
    • Remove the motor and shaft assembly from the bottom of the case housing.
    Ask FixBot
  6. Chef's Choice M115 Linkage Pins Replacement: step 6, image 1 of 2 Chef's Choice M115 Linkage Pins Replacement: step 6, image 2 of 2
    • Use a screwdriver to push the pin out of the rod.
    • Use pliers to pull the pin the rest of the way out.
    Ask FixBot
James Herin
128 Reputation
1 Guide authored
IUPUI, Team 3-3, Harley Fall 2015 Member of IUPUI, Team 3-3, Harley Fall 2015
IUPUI-HARLEY-F15S3G3
5 Members
14 Guides authored
1 Guide Comment
Where would you obtain new linkage pins. Can I use a similar gauged wire? What, and where can I find a suitable replacement?
Josh Brown - Reply Share
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 53
All Time: 2,411
