Chef’s Counter Rice Cooker RC-3 Disassembly
  1. Chef’s Counter Rice Cooker RC-3 Disassembly, Chef’s Counter Rice Cooker RC-3: step 1, image 1 of 3 Chef’s Counter Rice Cooker RC-3 Disassembly, Chef’s Counter Rice Cooker RC-3: step 1, image 2 of 3 Chef’s Counter Rice Cooker RC-3 Disassembly, Chef’s Counter Rice Cooker RC-3: step 1, image 3 of 3
    • Unplug the rice cooker.
    • Remove the bowl and lid from the device and place the device upside down on a flat surface.
    Ask FixBot
  2. Chef’s Counter Rice Cooker RC-3 Disassembly: step 2, image 1 of 3 Chef’s Counter Rice Cooker RC-3 Disassembly: step 2, image 2 of 3 Chef’s Counter Rice Cooker RC-3 Disassembly: step 2, image 3 of 3
    • Remove the two 13 mm screws from the bottom using a Phillips #1 screwdriver.
    • Remove the base plate.
    Ask FixBot
  3. Chef’s Counter Rice Cooker RC-3 Disassembly: step 3, image 1 of 3 Chef’s Counter Rice Cooker RC-3 Disassembly: step 3, image 2 of 3 Chef’s Counter Rice Cooker RC-3 Disassembly: step 3, image 3 of 3
    • Remove the three 10 mm gold screws holding the wires in place using a Phillips #1 screwdriver.
    Ask FixBot
  4. Chef’s Counter Rice Cooker RC-3 Disassembly: step 4, image 1 of 3 Chef’s Counter Rice Cooker RC-3 Disassembly: step 4, image 2 of 3 Chef’s Counter Rice Cooker RC-3 Disassembly: step 4, image 3 of 3
    • Remove the single 10 mm screw from the metal plate using a Phillips #1 screwdriver.
    • Remove the metal plate.
    Ask FixBot
  5. Chef’s Counter Rice Cooker RC-3 Disassembly: step 5, image 1 of 3 Chef’s Counter Rice Cooker RC-3 Disassembly: step 5, image 2 of 3 Chef’s Counter Rice Cooker RC-3 Disassembly: step 5, image 3 of 3
    • Remove the three perimeter screws holding the heating plate in place using a Phillips #1 screwdriver.
    • One screw has a length of 14 mm and two screws are 10 mm.
    Ask FixBot
  6. Chef’s Counter Rice Cooker RC-3 Disassembly: step 6, image 1 of 3 Chef’s Counter Rice Cooker RC-3 Disassembly: step 6, image 2 of 3 Chef’s Counter Rice Cooker RC-3 Disassembly: step 6, image 3 of 3
    • Use pliers to pinch the metal V in the center.
    • Slide out the silver heating component and black support ring.
    Ask FixBot
  7. Chef’s Counter Rice Cooker RC-3 Disassembly: step 7, image 1 of 3 Chef’s Counter Rice Cooker RC-3 Disassembly: step 7, image 2 of 3 Chef’s Counter Rice Cooker RC-3 Disassembly: step 7, image 3 of 3
    • Use the pliers to pinch the three metal flaps flat and remove the spring.
    Ask FixBot
  8. Chef’s Counter Rice Cooker RC-3 Disassembly: step 8, image 1 of 2 Chef’s Counter Rice Cooker RC-3 Disassembly: step 8, image 2 of 2
    • Remove the metal hook that is over the thick white wire cover.
    Ask FixBot
  9. Chef’s Counter Rice Cooker RC-3 Disassembly: step 9, image 1 of 2 Chef’s Counter Rice Cooker RC-3 Disassembly: step 9, image 2 of 2
    • Remove the thick white wire cover uncovering the thermal cutoff fuse.
    Ask FixBot
  10. Chef’s Counter Rice Cooker RC-3 Disassembly: step 10, image 1 of 2 Chef’s Counter Rice Cooker RC-3 Disassembly: step 10, image 2 of 2
    • Flip over the rice cooker so it is right side up.
    Ask FixBot
  11. Chef’s Counter Rice Cooker RC-3 Disassembly: step 11, image 1 of 3 Chef’s Counter Rice Cooker RC-3 Disassembly: step 11, image 2 of 3 Chef’s Counter Rice Cooker RC-3 Disassembly: step 11, image 3 of 3
    • Remove the single 10 mm screw from the outer control panel using a Phillips #1 screwdriver.
    • Remove the plastic outer control panel.
    Ask FixBot
  12. Chef’s Counter Rice Cooker RC-3 Disassembly: step 12, image 1 of 3 Chef’s Counter Rice Cooker RC-3 Disassembly: step 12, image 2 of 3 Chef’s Counter Rice Cooker RC-3 Disassembly: step 12, image 3 of 3
    • Remove the single 10 mm screw using a Phillips #1 screwdriver to reveal the LED lights.
    Ask FixBot
  13. Chef’s Counter Rice Cooker RC-3 Disassembly: step 13, image 1 of 3 Chef’s Counter Rice Cooker RC-3 Disassembly: step 13, image 2 of 3 Chef’s Counter Rice Cooker RC-3 Disassembly: step 13, image 3 of 3
    • Remove the single 27 mm screw using a hex 5.5 screwdriver.
    • Extra hands are helpful because this component will easily fall apart.
    Ask FixBot
  14. Chef’s Counter Rice Cooker RC-3 Disassembly: step 14, image 1 of 2 Chef’s Counter Rice Cooker RC-3 Disassembly: step 14, image 2 of 2
    • Inspect the outer control panel, mechanical lever, and the components of the stack.
    Ask FixBot
  15. Chef’s Counter Rice Cooker RC-3 Disassembly: step 15, image 1 of 1
    • Now that the device is disassembled you can get a better understanding on how it works.
    • The rice cooker receives constant power when plugged in. A mechanical lever is used to switch between warm and cook settings. The settings are indicated by white LED lights with orange and red plastic coverings on the outer control panel.
    • A DF184S Thermal Cutoff Fuse is in place to protect the device by disconnecting the circuit in the event of a heating element malfunction.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 28
All Time: 316
