Charging System reset
View statistics:
Past 24 Hours:
2
Past 7 Days:
13
Past 30 Days:
73
All Time:
669
Comments: 2
2 comments on steps.
Completed: 0
Favorites: 0
Time Required: 30 seconds
Difficulty: Very easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
Reset a Roomba discovery charging system that is malfunctioning
    1. Charging System reset, Flip over Roomba: step 1, image 1 of 1
      • Flip over Roomba
      Ask FixBot
    2. Charging System reset, Remove the battery: step 2, image 1 of 3 Charging System reset, Remove the battery: step 2, image 2 of 3 Charging System reset, Remove the battery: step 2, image 3 of 3
      • Depress the tabs on the sides of the battery and lift it out.
      • You may need to use descent force when lifting up.
      Ask FixBot
    3. Charging System reset, Reset the roomba: step 3, image 1 of 2 Charging System reset, Reset the roomba: step 3, image 2 of 2
      • Flip Roomba back over
      • Hold down Roomba's power button for 15 seconds.
      Ask FixBot
    4. Charging System reset, Reinstall the battery.: step 4, image 1 of 3 Charging System reset, Reinstall the battery.: step 4, image 2 of 3 Charging System reset, Reinstall the battery.: step 4, image 3 of 3
      • Flip Roomba back over.
      • Reinsert the battery.
      • Flip Roomba over again.
      Ask FixBot
    5. Charging System reset, Charge and run Roomba: step 5, image 1 of 1
      • Charge Roomba for 16 hours and run on MAX cycle.
      • You should be done!
      Ask FixBot
Perform an uninterrupted 16 hour charge. Then run on MAX cleaning cycle.
Austin Walter
1,353 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 73
All Time: 669
