Up to 20% off select tools
Charging Component on the Base Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
21
Past 30 Days:
108
All Time:
950
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓
Having suspicion that your handset is not charging well due to bad contact? You've come to the right guide!
    1. Charging Component on the Base Replacement, Base: step 1, image 1 of 1
      • Turn the base over. You will see four 11mm Phillips #0 screws, one in each corner.
      • Use a screwdriver to remove all four 11mm Phillips #0 screws.
      Ask FixBot
    2. Charging Component on the Base Replacement: step 2, image 1 of 2 Charging Component on the Base Replacement: step 2, image 2 of 2
      • Locate an easy seam for entry and insert the metal spudger to separate the plastic. Use the spudger in multiple places if necessary.
      • Opening the base may require exerting significant force as it is bound together tightly. This step can be dangerous.
      • The spudger is designed to make this step easier.
      Ask FixBot
    1. Charging Component on the Base Replacement, Charging Component on the Base: step 3, image 1 of 2 Charging Component on the Base Replacement, Charging Component on the Base: step 3, image 2 of 2
      • Locate the charging component towards the bottom of the grey, plastic, phone-shaped extrusion. It is composed of two metal pieces; each is fastened by a 5mm Phillips #0 screw.
      • Remove both 5mm Phillips #0 screws to release the metal pieces.
      Ask FixBot
    2. Charging Component on the Base Replacement: step 4, image 1 of 1
      • Cut the black and red wires to finish removal, and then solder your new replacement component.
      • For more help on soldering, please refer to the iFixit Solder and Desolder Guide.
      Ask FixBot
2 other people completed this guide.
Author
with
Han Shih
394 Reputation
4 Guides authored
IUPUI, Team 3-3, Harley Fall 2016 Member of IUPUI, Team 3-3, Harley Fall 2016
IUPUI-HARLEY-F16S3G3
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 21
Past 30 Days: 108
All Time: 950
