Charge 3 Touch Screen Assembly Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
4
Past 7 Days:
19
Past 30 Days:
88
All Time:
1,286
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 minutes - 1 hour
Difficulty: Moderate
Community-Contributed Guide
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
This repair fixes a common issue on this device, after a few months of use the screen slowly gets dimmer before dying.
Parts
Tools
    1. Charge 3 Touch Screen Assembly Replacement, Touch Screen Assembly: step 1, image 1 of 3 Charge 3 Touch Screen Assembly Replacement, Touch Screen Assembly: step 1, image 2 of 3 Charge 3 Touch Screen Assembly Replacement, Touch Screen Assembly: step 1, image 3 of 3
      • It is recommended to let the battery discharge before starting. It's a precaution to prevent the battery from catching fire if punctured.
      • Remove both T2 screws
      • Slide off the plastic piece by lifting out and then up
      • Slide plastic and spring assembly off the rail
      • Do this on both sides
      Ask FixBot
    2. Charge 3 Touch Screen Assembly Replacement: step 2, image 1 of 3 Charge 3 Touch Screen Assembly Replacement: step 2, image 2 of 3 Charge 3 Touch Screen Assembly Replacement: step 2, image 3 of 3
      • I've performed this on a few Fitbits where the adhesive was worn out enough that with a light amount of prying the touch screen assembly lifts right up
      • A hairdryer on high should work you may have to use it for longer
      • Heat the glass screen with heat gun to soften the adhesives
      • Insert a razor blade between the glass and the body
      • Keep going around the rim of the display until loose
      Ask FixBot
    3. Charge 3 Touch Screen Assembly Replacement: step 3, image 1 of 1
      • This is how close those cables get to the edge underneath the Fitbit letters so be careful
      Ask FixBot
    4. Charge 3 Touch Screen Assembly Replacement: step 4, image 1 of 3 Charge 3 Touch Screen Assembly Replacement: step 4, image 2 of 3 Charge 3 Touch Screen Assembly Replacement: step 4, image 3 of 3
      • Lift the display then battery up gently
      • The battery is attached with a little bit of adhesive so lift gently
      • Remove battery connector
      Ask FixBot
    5. Charge 3 Touch Screen Assembly Replacement: step 5, image 1 of 2 Charge 3 Touch Screen Assembly Replacement: step 5, image 2 of 2
      • Remove two P2 screws
      • Remove T2 screw
      • Liftoff metal shield
      • I found flipping the device and letting the shield fall out was easier
      Ask FixBot
    6. Charge 3 Touch Screen Assembly Replacement: step 6, image 1 of 3 Charge 3 Touch Screen Assembly Replacement: step 6, image 2 of 3 Charge 3 Touch Screen Assembly Replacement: step 6, image 3 of 3
      • Liftoff both display connectors
      • Remove Display Assembly
      Ask FixBot
      • Connect The new screen (basically step 6 in reverse)
      • This step can be a bit fiddly to get right
      • Then perform the step 5 in reverse to put the metal shield back in
      Ask FixBot
    7. Charge 3 Touch Screen Assembly Replacement: step 8, image 1 of 2 Charge 3 Touch Screen Assembly Replacement: step 8, image 2 of 2
      • Reconnect battery connector
      • if the battery wasn't dead before repair it should turn on now
      • Put the battery back in place
      • When I was replacing the screen I also replaced the battery that's why the battery changed.
      Ask FixBot
    8. Charge 3 Touch Screen Assembly Replacement: step 9, image 1 of 1
      • Add a thin layer of E-6000 glue around the casing
      • Make sure to cover the entire surface that makes contact with the screen to keep the device waterproof
      Ask FixBot
    9. Charge 3 Touch Screen Assembly Replacement: step 10, image 1 of 2 Charge 3 Touch Screen Assembly Replacement: step 10, image 2 of 2
      • Flip down the screen and remove any extra glue that squeezes out
      • Take a rubber band and wrap it around the device, this will ensure the display stays in place until the glue cures
      • With the rubber bands on go to step 1 and reverse the steps to reinstall the band release
      • The glue will take between 24 and 72 hours to fully cure
      Ask FixBot
      • When the glue is fully cured remove the rubber bands
      • And voila you now have a repaired Fitbit Charge 3
      Ask FixBot
Thanks to ShellingRook27's Original Dissasembly I Was Able to Make this Guide And Bring a new life to my old device.
2 other people completed this guide.
Supper Simon
464 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 88
All Time: 1,286
