Up to 20% off select tools
Charge 3 Disassembly
Views: 13K
View statistics:
Past 24 Hours:
4
Past 7 Days:
30
Past 30 Days:
147
All Time:
12,851
Comments: 19
7 comments on steps, 12 guide comments.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
Tools
    1. Charge 3 Disassembly, Strap Connectors: step 1, image 1 of 3 Charge 3 Disassembly, Strap Connectors: step 1, image 2 of 3 Charge 3 Disassembly, Strap Connectors: step 1, image 3 of 3
      • Remove both T3 screws
      • Slide off the plastic piece by lifting out and then up
      • Slide plastic and spring assembly off the rail
      Ask FixBot
    2. Charge 3 Disassembly, Display: step 2, image 1 of 3 Charge 3 Disassembly, Display: step 2, image 2 of 3 Charge 3 Disassembly, Display: step 2, image 3 of 3
      • Heat the glass screen with a blowdryer to soften the adhesives
      • Start the next step on the opposite side of the Fitbit wording below the glass. This is due to the display cables being located there
      • Insert a razor blade between the glass and the body
      • Keep going around the rim of the display until loose
      Ask FixBot
    3. Charge 3 Disassembly, Cable Warning: step 3, image 1 of 1
      • This is how close those cables get to the edge underneath the Fitbit wording so be careful
      Ask FixBot
    4. Charge 3 Disassembly, Battery: step 4, image 1 of 3 Charge 3 Disassembly, Battery: step 4, image 2 of 3 Charge 3 Disassembly, Battery: step 4, image 3 of 3
      • Lift display up gently
      • The battery is attached with a little bit of adhesive so lift gently
      • Remove battery connector
      Ask FixBot
    5. Charge 3 Disassembly, Vibrator Shield: step 5, image 1 of 2 Charge 3 Disassembly, Vibrator Shield: step 5, image 2 of 2
      • Remove both T2 screws
      • Liftoff metal shield
      Ask FixBot
    6. Charge 3 Disassembly, Main Shield: step 6, image 1 of 3 Charge 3 Disassembly, Main Shield: step 6, image 2 of 3 Charge 3 Disassembly, Main Shield: step 6, image 3 of 3
      • Remove two T2 screws
      • Remove T3 screw
      Ask FixBot
    7. Charge 3 Disassembly, Display Connectors: step 7, image 1 of 3 Charge 3 Disassembly, Display Connectors: step 7, image 2 of 3 Charge 3 Disassembly, Display Connectors: step 7, image 3 of 3
      • Liftoff both display connectors
      Ask FixBot
    8. Charge 3 Disassembly, Disconnect Connectors and Altimeter: step 8, image 1 of 2 Charge 3 Disassembly, Disconnect Connectors and Altimeter: step 8, image 2 of 2
      • Disconnect vibrator motor
      • Disconnect heartrate and charging connector
      • Remove altimeter
      Ask FixBot
    9. Charge 3 Disassembly, Side Button and Vibrator: step 9, image 1 of 3 Charge 3 Disassembly, Side Button and Vibrator: step 9, image 2 of 3 Charge 3 Disassembly, Side Button and Vibrator: step 9, image 3 of 3
      • Remove button assembly from case
      • Remove vibrator motor
      • Has a slight bit of adhesive and is magnetic to the case
      Ask FixBot
    10. Charge 3 Disassembly, Motherboard: step 10, image 1 of 2 Charge 3 Disassembly, Motherboard: step 10, image 2 of 2
      • Remove motherboard
      • It seems as if the heart rate sensor and charging pins are molded into the case, and I was not able to remove them
      Ask FixBot
Finish Line
4 other people completed this guide.
Author
with
ShellingRook27
2,383 Reputation
7 Guides authored
Repair For You Member of Repair For You
Business
1 Member
84 Guides authored
12 Guide Comments
The tear down pictures are great, but in my Charge 3 I needed a T-1 and a T-2 driver
Julien Baldwin - Reply Share
Same, my ifixit pro kit only had a driver for the external screws and did not come with a small enough driver to remove the screws inside the charge 3 unit. I'll need to get the smaller bit from a different kit.
Brian Hall - Reply Share
Which step in the teardown guide needed the T1 driver?
ShellingRook27 - Reply Share
Great job on this tear-down. Thank you, it really helped in my screen replacement.
AndyZ - Reply Share
This tear down was very easy to follow. The heart rate monitor was also sealed in with some adhesive for me too but a little heat gun took it right off. I had suspected water leaked in and that in fact was the culprit after inspecting the connection. corrosion all around the HR monitor.
Nick Herbert - Reply Share
Past 24 Hours: 4
Past 7 Days: 30
Past 30 Days: 147
All Time: 12,851
