Change the Presser Foot on a Sewing Machine
Views: 57K
View statistics:
Past 24 Hours:
14
Past 7 Days:
105
Past 30 Days:
358
All Time:
57,240
Comments: 1
1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 17
17 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Very easy
Patagonia
Patagonia and iFixit are celebrating the stories we wear by collaborating to provide guides for Patagonia's most popular apparel repairs.
Introduction
Go to step 1 ↓
Swapping out the presser foot lets you create different stitches for different sewing tasks, such as buttonholes, zippers, zigzag, etc. Use this guide to change the presser foot in your sewing machine. We’re using a Bernina 830 for this procedure; sewing machines can vary, so check your sewing machine's owner’s manual for specific instructions.
Return to the Patagonia Care & Repair homepage.
    1. Change the Presser Foot on a Sewing Machine, Change the Presser Foot on a Sewing Machine: step 1, image 1 of 2 Change the Presser Foot on a Sewing Machine, Change the Presser Foot on a Sewing Machine: step 1, image 2 of 2
      • Set the sewing machine needle to the upright position by turning the balance wheel towards you.
      • Release the presser foot lever by sliding it up.
      • The presser foot will just fall out. Be ready to grab it.
      Ask FixBot
    2. Change the Presser Foot on a Sewing Machine: step 2, image 1 of 3 Change the Presser Foot on a Sewing Machine: step 2, image 2 of 3 Change the Presser Foot on a Sewing Machine: step 2, image 3 of 3
      • Pull the presser foot down and slide it off the peg on the machine.
      • Be careful not to break the needle.
      Ask FixBot
    3. Change the Presser Foot on a Sewing Machine: step 3, image 1 of 3 Change the Presser Foot on a Sewing Machine: step 3, image 2 of 3 Change the Presser Foot on a Sewing Machine: step 3, image 3 of 3
      • Grab your desired presser foot, and orient it foot-down.
      • Take the foot at an angle and slide the hole in the top of the presser foot onto the peg on the sewing machine.
      Ask FixBot
    4. Change the Presser Foot on a Sewing Machine: step 4, image 1 of 2 Change the Presser Foot on a Sewing Machine: step 4, image 2 of 2
      • Slide the presser foot lever down to lock the new foot in place.
      • Be sure to check your manual to see if you need to adjust the needle position. If it's not correctly adjusted, you may hit the needle on the presser foot and break the needle while sewing.
      Ask FixBot
Finish Line
2 other people completed this guide.
Brittany McCrigler
91,111 Reputation
142 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,885 Guides authored
1 Guide Comment
Tolle Anleitung, vielen Dank und wie kann man die Drehteile ersetzen wo die Fäden reinkommen? Kann ich das selbst ersetzen oder muss ein Fachmann her?
Ben - Reply Share
Past 24 Hours: 14
Past 7 Days: 105
Past 30 Days: 358
All Time: 57,240
