Change Packard Bell memory (install)
Views: 3K
View statistics:
Past 24 Hours:
3
Past 7 Days:
23
Past 30 Days:
128
All Time:
3,030
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 15 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
this repair guide will help you to swap the memory of your Packard Bell.
    1. Change Packard Bell memory (install), Change memory: step 1, image 1 of 3 Change Packard Bell memory (install), Change memory: step 1, image 2 of 3 Change Packard Bell memory (install), Change memory: step 1, image 3 of 3
      • Turn off the laptop completely.
      • Remove the two Phillips # 000 screws and remove the cover.
      • Use your fingers to undo the case on the bottom.
      Ask FixBot
    2. Change Packard Bell memory (install): step 2, image 1 of 3 Change Packard Bell memory (install): step 2, image 2 of 3 Change Packard Bell memory (install): step 2, image 3 of 3
      • To the right of the already installed RAM modules, you will find the brackets that secure the RAM in the bracket. Press the two clips outwards.
      • The Ram chip folds up slightly after unlocking and can then be easily removed. Repeat this process to remove the second RAM as well.
      • Insert the new RAM and press it down with a little pressure, so that the memory is back in the holder.
      Ask FixBot
Repeat the steps in order to reassemble your device.
Special thanks to these translators:
de en
100%
irlanda is helping us fix the world! Want to contribute?
Start translating ›
Sandro
128 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 23
Past 30 Days: 128
All Time: 3,030
