Up to 20% off select tools
Cen-Tech Seven Function Digital Multimeter Screen Replacement
Views: 3.5K
View statistics:
Past 24 Hours:
2
Past 7 Days:
19
Past 30 Days:
111
All Time:
3,463
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Easy
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Parts
Tools
Introduction
Go to step 1 ↓
If the screen is cracked or not working it may be necessary to replace it. This guide will show how to conduct a screen replacement.
    1. Cen-Tech Seven Function Digital Multimeter Screen Replacement, Position Device: step 1, image 1 of 1
      • Place the meter face down, and the back panel and screws can be seen.
      Ask FixBot
    2. Cen-Tech Seven Function Digital Multimeter Screen Replacement, Remove Back Panel Screws: step 2, image 1 of 2 Cen-Tech Seven Function Digital Multimeter Screen Replacement, Remove Back Panel Screws: step 2, image 2 of 2
      • Unscrew the two 9mm screws on the back panel using a #0 Phillips screwdriver.
      Ask FixBot
    3. Cen-Tech Seven Function Digital Multimeter Screen Replacement, Remove Back Panel: step 3, image 1 of 1
      • Remove the back panel of the device by lifting upward.
      • Remove the battery from the meter before continuing.
      Ask FixBot
    4. Cen-Tech Seven Function Digital Multimeter Screen Replacement, Unscrew Motherboard: step 4, image 1 of 2 Cen-Tech Seven Function Digital Multimeter Screen Replacement, Unscrew Motherboard: step 4, image 2 of 2
      • Remove the four 7mm Phillips screws holding the circuit board in place.
      Ask FixBot
    5. Cen-Tech Seven Function Digital Multimeter Screen Replacement, Remove Motherboard: step 5, image 1 of 1
      • Gently lift the circuit board away from the device casing.
      • Remove the battery after removing the back cover to reduce the chances of short-circuiting the circuit board.
      Ask FixBot
    1. Cen-Tech Seven Function Digital Multimeter Screen Replacement, Locate Screen: step 6, image 1 of 1
      • The screen is located at the top of the device.
      Ask FixBot
    2. Cen-Tech Seven Function Digital Multimeter Screen Replacement, Remove Screen: step 7, image 1 of 1
      • Carefully remove screen from device by lifting upward.
      Ask FixBot
Author
with
Anna Kihm
965 Reputation
5 Guides authored
Clemson, Team 2-4, Benson Fall 2014 Member of Clemson, Team 2-4, Benson Fall 2014
CLEM-BENSON-F14S2G4
4 Members
72 Guides authored
1 Guide Comment
my multimeter display is broken, where can i buy a new one?
allwynrajkumar - Reply Share
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 111
All Time: 3,463
