Cen-Tech Seven Function Digital Multimeter Circuit Board Replacement
    1. Cen-Tech Seven Function Digital Multimeter Circuit Board Replacement, Position Device: step 1, image 1 of 1
      • Place the meter face down, and the back panel and screws can be seen.
      Ask FixBot
    2. Cen-Tech Seven Function Digital Multimeter Circuit Board Replacement, Remove Back Panel Screws: step 2, image 1 of 2 Cen-Tech Seven Function Digital Multimeter Circuit Board Replacement, Remove Back Panel Screws: step 2, image 2 of 2
      • Unscrew the two 9mm screws on the back panel using a #0 Phillips screwdriver.
      Ask FixBot
    3. Cen-Tech Seven Function Digital Multimeter Circuit Board Replacement, Remove Back Panel: step 3, image 1 of 1
      • Remove the back panel of the device by lifting upward.
      • Remove the battery from the meter before continuing.
      Ask FixBot
    4. Cen-Tech Seven Function Digital Multimeter Circuit Board Replacement, Unscrew Motherboard: step 4, image 1 of 2 Cen-Tech Seven Function Digital Multimeter Circuit Board Replacement, Unscrew Motherboard: step 4, image 2 of 2
      • Remove the four 7mm Phillips screws holding the circuit board in place.
      Ask FixBot
    5. Cen-Tech Seven Function Digital Multimeter Circuit Board Replacement, Remove Motherboard: step 5, image 1 of 1
      • Gently lift the circuit board away from the device casing.
      • Remove the battery after removing the back cover to reduce the chances of short-circuiting the circuit board.
      Ask FixBot
6 other people completed this guide.
Anna Kihm
965 Reputation
5 Guides authored
Clemson, Team 2-4, Benson Fall 2014 Member of Clemson, Team 2-4, Benson Fall 2014
CLEM-BENSON-F14S2G4
4 Members
72 Guides authored
1 Guide Comment
What is the little dial on the circuit board on the upper right that has numbers 1 through 3 on it and it can be adjusted thank you
Thomas Clawson - Reply Share
Past 24 Hours: 5
Past 7 Days: 12
Past 30 Days: 45
All Time: 3,240
