Up to 20% off select tools
Cen-Tech Seven Function Digital Multimeter Battery Replacement
Views: 17K
View statistics:
Past 24 Hours:
11
Past 7 Days:
40
Past 30 Days:
191
All Time:
16,979
Comments: 6
6 guide comments.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Parts
Tools
Introduction
Go to step 1 ↓
If the device is unable to turn on, it may be necessary to replace the battery. This guide will show how to remove the old battery, and how to replace it with a new one.
    1. Cen-Tech Seven Function Digital Multimeter Battery Replacement, Position Device: step 1, image 1 of 1
      • Place the meter face down, and the back panel and screws can be seen.
      Ask FixBot
    2. Cen-Tech Seven Function Digital Multimeter Battery Replacement, Remove Back Panel Screws: step 2, image 1 of 2 Cen-Tech Seven Function Digital Multimeter Battery Replacement, Remove Back Panel Screws: step 2, image 2 of 2
      • Unscrew the two 9mm screws on the back panel using a #0 Phillips screwdriver.
      Ask FixBot
    3. Cen-Tech Seven Function Digital Multimeter Battery Replacement, Remove Back Panel: step 3, image 1 of 1
      • Remove the back panel of the device by lifting upward.
      • Remove the battery from the meter before continuing.
      Ask FixBot
    4. Cen-Tech Seven Function Digital Multimeter Battery Replacement, Unscrew Motherboard: step 4, image 1 of 2 Cen-Tech Seven Function Digital Multimeter Battery Replacement, Unscrew Motherboard: step 4, image 2 of 2
      • Remove the four 7mm Phillips screws holding the circuit board in place.
      Ask FixBot
    5. Cen-Tech Seven Function Digital Multimeter Battery Replacement, Remove Motherboard: step 5, image 1 of 1
      • Gently lift the circuit board away from the device casing.
      • Remove the battery after removing the back cover to reduce the chances of short-circuiting the circuit board.
      Ask FixBot
    1. Cen-Tech Seven Function Digital Multimeter Battery Replacement, Locate Battery Attachment: step 6, image 1 of 1
      • After removing the outer casing and motherboard of the device, locate the attachment site of the battery to the motherboard.
      Ask FixBot
    2. Cen-Tech Seven Function Digital Multimeter Battery Replacement, Remove Battery: step 7, image 1 of 1
      • Unsnap the battery from its attachment plate.
      • When replacing the battery with a new one, be sure to properly align battery heads (positive and negative) with snaps. The positive battery head should be connected to the negative wire, and vice versa.
      Ask FixBot
4 other people completed this guide.
Author
with
Anna Kihm
965 Reputation
5 Guides authored
Clemson, Team 2-4, Benson Fall 2014 Member of Clemson, Team 2-4, Benson Fall 2014
CLEM-BENSON-F14S2G4
4 Members
72 Guides authored
6 Guide Comments
My case was glued or welded together. I thought it was going to break elsewhere first
No need to remove the board. Just use a screwdriver to pop the battery connector off
Osman Vincent - Reply Share
In at least some of these meters, the caution label has been applied upside-down, so that it covers the screw holes.
dan - Reply Share
The top of the panel has two tabs engaged (can be seen by carefully examining photos above). After screws are freed, lift the bottom edge first to allow tabs to disengage. Also, routing of battery clip wires is critical; take care that they clear the case edges.
dan - Reply Share
Can't get 2nd screw out!!
KARIN SPURLING - Reply Share
I had a spring in mine, and when my grandson took it apart to change battery, I don’t know where the spring came out
Rodney Grainger - Reply Share
Past 24 Hours: 11
Past 7 Days: 40
Past 30 Days: 191
All Time: 16,979
