Cen-Tech Seven Function Digital Multimeter Ball Bearings Replacement
    1. Cen-Tech Seven Function Digital Multimeter Ball Bearings Replacement, Position Device: step 1, image 1 of 1
      • Place the meter face down, and the back panel and screws can be seen.
      Ask FixBot
    2. Cen-Tech Seven Function Digital Multimeter Ball Bearings Replacement, Remove Back Panel Screws: step 2, image 1 of 2 Cen-Tech Seven Function Digital Multimeter Ball Bearings Replacement, Remove Back Panel Screws: step 2, image 2 of 2
      • Unscrew the two 9mm screws on the back panel using a #0 Phillips screwdriver.
      Ask FixBot
    3. Cen-Tech Seven Function Digital Multimeter Ball Bearings Replacement, Remove Back Panel: step 3, image 1 of 1
      • Remove the back panel of the device by lifting upward.
      • Remove the battery from the meter before continuing.
      Ask FixBot
    4. Cen-Tech Seven Function Digital Multimeter Ball Bearings Replacement, Unscrew Motherboard: step 4, image 1 of 2 Cen-Tech Seven Function Digital Multimeter Ball Bearings Replacement, Unscrew Motherboard: step 4, image 2 of 2
      • Remove the four 7mm Phillips screws holding the circuit board in place.
      Ask FixBot
    5. Cen-Tech Seven Function Digital Multimeter Ball Bearings Replacement, Remove Motherboard: step 5, image 1 of 1
      • Gently lift the circuit board away from the device casing.
      • Remove the battery after removing the back cover to reduce the chances of short-circuiting the circuit board.
      Ask FixBot
    1. Cen-Tech Seven Function Digital Multimeter Ball Bearings Replacement, Locate Dial: step 6, image 1 of 1
      • The dial is located in the central part of the device.
      Ask FixBot
    2. Cen-Tech Seven Function Digital Multimeter Ball Bearings Replacement, Remove Dial: step 7, image 1 of 1
      • Carefully remove dial from device by lifting upward.
      • Clean existing dial or replace if necessary.
      • Take care not to lose the small ball bearings.
      Ask FixBot
    1. Cen-Tech Seven Function Digital Multimeter Ball Bearings Replacement, Locate and Remove Ball Bearings: step 8, image 1 of 1
      • Locate ball bearings. Carefully remove.
      • If both ball bearings are still present, try lubricating ball bearings with multi-use lubricant.
      • If one or both ball bearings are missing, simply replace.
      Ask FixBot
4 other people completed this guide.
Anna Kihm
965 Reputation
5 Guides authored
Clemson, Team 2-4, Benson Fall 2014 Member of Clemson, Team 2-4, Benson Fall 2014
CLEM-BENSON-F14S2G4
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 35
All Time: 2,834
