Up to 20% off select tools
Cello String Replacement
Views: 2.2K
View statistics:
Past 24 Hours:
11
Past 7 Days:
47
Past 30 Days:
153
All Time:
2,201
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 7 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Replacing a string on an instrument can be scary. You always want to make sure that you don’t break the replacement! In this guide, we will show you how to remove and replace the string on a cello. These steps would also work perfectly for another orchestral string instrument, such as a violin, viola, or bass. Simply follow the steps and be back to playing your instrument in less than ten minutes!
    1. Cello String Replacement, String: step 1, image 1 of 2 Cello String Replacement, String: step 1, image 2 of 2
      • Follow the string up to the peg of the corresponding string. Grab it, and twist it towards you.
      Ask FixBot
    2. Cello String Replacement: step 2, image 1 of 1
      • Once the peg is loose, follow the string down to the fine tuner, and loosen that as well.
      Ask FixBot
    3. Cello String Replacement: step 3, image 1 of 2 Cello String Replacement: step 3, image 2 of 2
      • Remove the string and take out your replacement. Insert the end of the string with the bead in it into the fine tuner slot.
      Ask FixBot
    4. Cello String Replacement: step 4, image 1 of 1
      • With the string in the fine tuner slot, line the string up with the rivet in the bridge.
      Ask FixBot
    5. Cello String Replacement: step 5, image 1 of 2 Cello String Replacement: step 5, image 2 of 2
      • Place the string into the small hole in the peg. Make sure that it gets far enough in!
      • About half an inch of string poking out the other side is optimal.
      Ask FixBot
    6. Cello String Replacement: step 6, image 1 of 1
      • Re-line the string with the bridge, in case it fell out.
      • Make sure that the string is in the position you want it to be - evenly spaced between the strings between them.
      Ask FixBot
    7. Cello String Replacement: step 7, image 1 of 1
      • Twist the peg in the opposite direction that you did before. If the cello is facing towards you, then twist it away from you.
      • Make sure that you do not twist too much! Pluck the string while twisting to make sure the string is not too loose or too tight. You don't want to snap it!
      • When tightening the peg, make sure that the string is still aligned with the indent on the bridge.
      Ask FixBot
Finish Line
Author
with
Austin Rosefeld
145 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 11
Past 7 Days: 47
Past 30 Days: 153
All Time: 2,201
