Ceiva LF2003 Power Supply Board Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
22
Past 30 Days:
92
All Time:
679
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 20 minutes
Difficulty: Difficult
Introduction
Go to step 1 ↓
Use this guide to replace the power supply board of the device. This includes detaching the power cables connected to the logic board, which requires desoldering.
Tools
    1. Ceiva LF2003 Power Supply Board Replacement, Exterior Frame and Matting: step 1, image 1 of 1
      • Lay the device on its back, and rotate so the base is facing away from you.
      Ask FixBot
    2. Ceiva LF2003 Power Supply Board Replacement: step 2, image 1 of 1
      • Grip the frame with your fingers under the edge of the frame, and thumbs pushing down on the front of the device.
      Ask FixBot
    3. Ceiva LF2003 Power Supply Board Replacement: step 3, image 1 of 1
      • Lift up the frame with your fingers and push down the rest of the device with your thumbs.
      Ask FixBot
    4. Ceiva LF2003 Power Supply Board Replacement: step 4, image 1 of 1
      • Remove the frame and matte from the device.
      Ask FixBot
    1. Ceiva LF2003 Power Supply Board Replacement, Internal Plastic Screen Frame: step 5, image 1 of 1
      • Remove the four 7mm Torx T6 screws.
      Ask FixBot
    2. Ceiva LF2003 Power Supply Board Replacement: step 6, image 1 of 2 Ceiva LF2003 Power Supply Board Replacement: step 6, image 2 of 2
      • Using the plastic opening tool or your fingers, lift up the frame from any edge.
      • Remove the frame from the device.
      Ask FixBot
    1. Ceiva LF2003 Power Supply Board Replacement, Display: step 7, image 1 of 3 Ceiva LF2003 Power Supply Board Replacement, Display: step 7, image 2 of 3 Ceiva LF2003 Power Supply Board Replacement, Display: step 7, image 3 of 3
      • Unplug the cable connecting the display to the power supply using the flat end of the spudger to pry the connector away from the circuit board.
      • Alternate applying pressure to the left and right side of the connector to ensure that it does not break.
      Ask FixBot
    2. Ceiva LF2003 Power Supply Board Replacement: step 8, image 1 of 1
      Ask FixBot
    3. Ceiva LF2003 Power Supply Board Replacement: step 9, image 1 of 2 Ceiva LF2003 Power Supply Board Replacement: step 9, image 2 of 2
      • Lift up the display from the left edge and flip display over.
      • Do not lift the display too quickly, as the display is still connected to the main circuit board on the right.
      Ask FixBot
    4. Ceiva LF2003 Power Supply Board Replacement: step 10, image 1 of 3 Ceiva LF2003 Power Supply Board Replacement: step 10, image 2 of 3 Ceiva LF2003 Power Supply Board Replacement: step 10, image 3 of 3
      • Use the spudger to disconnect the ribbon cable from the display by the black pins away from the connector. There is a pin on either side of the connector.
      • Once both pins are released, the ribbon cable should slide easily out.
      • It may be easier if someone else holds the display so the cable does not get ripped out.
      Ask FixBot
    5. Ceiva LF2003 Power Supply Board Replacement: step 11, image 1 of 1
      • Remove the display assembly from the device.
      Ask FixBot
    1. Ceiva LF2003 Power Supply Board Replacement, Power Supply Board: step 12, image 1 of 1
      Ask FixBot
    2. Ceiva LF2003 Power Supply Board Replacement: step 13, image 1 of 2 Ceiva LF2003 Power Supply Board Replacement: step 13, image 2 of 2
      • Desolder the 3 wires attached to the board.
      • Remove the power supply board from the device.
      • The wires shown were not actually desoldered, but the board will now be separated from the rest of the device.
      Ask FixBot
Casey Glasgow
510 Reputation
5 Guides authored
Cal Poly, Team 9-25, Maness Winter 2014 Member of Cal Poly, Team 9-25, Maness Winter 2014
CPSU-MANESS-W14S9G25
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 22
Past 30 Days: 92
All Time: 679
