Ceiva LF2003 Internal Plastic Screen Frame Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
28
Past 30 Days:
93
All Time:
560
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Introduction
Go to step 1 ↓
Replacing the internal frame on this device is very simple and requires minimal disassembly.
    1. Ceiva LF2003 Internal Plastic Screen Frame Replacement, Exterior Frame and Matting: step 1, image 1 of 1
      • Lay the device on its back, and rotate so the base is facing away from you.
      Ask FixBot
    2. Ceiva LF2003 Internal Plastic Screen Frame Replacement: step 2, image 1 of 1
      • Grip the frame with your fingers under the edge of the frame, and thumbs pushing down on the front of the device.
      Ask FixBot
    3. Ceiva LF2003 Internal Plastic Screen Frame Replacement: step 3, image 1 of 1
      • Lift up the frame with your fingers and push down the rest of the device with your thumbs.
      Ask FixBot
    4. Ceiva LF2003 Internal Plastic Screen Frame Replacement: step 4, image 1 of 1
      • Remove the frame and matte from the device.
      Ask FixBot
    1. Ceiva LF2003 Internal Plastic Screen Frame Replacement, Internal Plastic Screen Frame: step 5, image 1 of 1
      • Remove the four 7mm Torx T6 screws.
      Ask FixBot
    2. Ceiva LF2003 Internal Plastic Screen Frame Replacement: step 6, image 1 of 2 Ceiva LF2003 Internal Plastic Screen Frame Replacement: step 6, image 2 of 2
      • Using the plastic opening tool or your fingers, lift up the frame from any edge.
      • Remove the frame from the device.
      Ask FixBot
Casey Glasgow
510 Reputation
5 Guides authored
Cal Poly, Team 9-25, Maness Winter 2014 Member of Cal Poly, Team 9-25, Maness Winter 2014
CPSU-MANESS-W14S9G25
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 28
Past 30 Days: 93
All Time: 560
