Ceiva LF2003 Exterior Frame and Matting Replacement
    1. Ceiva LF2003 Exterior Frame and Matting Replacement, Exterior Frame and Matting: step 1, image 1 of 1
      • Lay the device on its back, and rotate so the base is facing away from you.
      Ask FixBot
    2. Ceiva LF2003 Exterior Frame and Matting Replacement: step 2, image 1 of 1
      • Grip the frame with your fingers under the edge of the frame, and thumbs pushing down on the front of the device.
      Ask FixBot
    3. Ceiva LF2003 Exterior Frame and Matting Replacement: step 3, image 1 of 1
      • Lift up the frame with your fingers and push down the rest of the device with your thumbs.
      Ask FixBot
    4. Ceiva LF2003 Exterior Frame and Matting Replacement: step 4, image 1 of 1
      • Remove the frame and matte from the device.
      Ask FixBot
Casey Glasgow
510 Reputation
5 Guides authored
Cal Poly, Team 9-25, Maness Winter 2014 Member of Cal Poly, Team 9-25, Maness Winter 2014
CPSU-MANESS-W14S9G25
4 Members
40 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 21
All Time: 389
