Up to 20% off select tools
Ceiling Fan Pull Chain Switch Replacement
Views: 22K
View statistics:
Past 24 Hours:
25
Past 7 Days:
208
Past 30 Days:
727
All Time:
21,755
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Parts
Tools
Introduction
Go to step 1 ↓
This guide will show you how to replace a ceiling fan pull chain switch.
Ceiling fan pull chains can break in two different ways:
  1. Chain breaks somewhere in the middle, outside the fan housing
    • In this case, the chain can be fixed by adding an extension chain.
  2. Chain breaks inside the fan housing
    • The chain will not be visible from the outside, so the fan housing must be opened to replace the chain or the pull chain switch itself.
This is a guide for replacing the pull chain switch.
Warning: Following this guide may expose you to voltage. Turn off the power from the circuit breaker and turn off any light switches that provide power to the ceiling fan to prevent injury.
    1. Ceiling Fan Pull Chain Switch Replacement, Pull Chain Switch: step 1, image 1 of 2 Ceiling Fan Pull Chain Switch Replacement, Pull Chain Switch: step 1, image 2 of 2
      • Caution: Turn off the power from the circuit breaker and turn off any light switches that provide power to the ceiling fan.
      • Remove the white cover by unscrewing the nut on the bottom from where the chain is hanging.
      Ask FixBot
    2. Ceiling Fan Pull Chain Switch Replacement: step 2, image 1 of 3 Ceiling Fan Pull Chain Switch Replacement: step 2, image 2 of 3 Ceiling Fan Pull Chain Switch Replacement: step 2, image 3 of 3
      • Caution: Let the bulbs cool off before you remove them.
      • Remove the bulbs from their sockets.
      Ask FixBot
    3. Ceiling Fan Pull Chain Switch Replacement: step 3, image 1 of 2 Ceiling Fan Pull Chain Switch Replacement: step 3, image 2 of 2
      • Remove the screws around the base.
      • Remove the fan housing.
      Ask FixBot
    4. Ceiling Fan Pull Chain Switch Replacement: step 4, image 1 of 1
      • Pull the switch out of the fan housing, leaving the wires attached.
      Ask FixBot
    5. Ceiling Fan Pull Chain Switch Replacement: step 5, image 1 of 3 Ceiling Fan Pull Chain Switch Replacement: step 5, image 2 of 3 Ceiling Fan Pull Chain Switch Replacement: step 5, image 3 of 3
      • Cut the colored wires from the switch using a pair of wire cutters.
      • On some switch models, the wires can be detached by pulling.
      Ask FixBot
    6. Ceiling Fan Pull Chain Switch Replacement: step 6, image 1 of 3 Ceiling Fan Pull Chain Switch Replacement: step 6, image 2 of 3 Ceiling Fan Pull Chain Switch Replacement: step 6, image 3 of 3
      • Note the wire colors and the terminal they attach to on the old switch.
      • 1 - Red
      • 2 - Purple
      • 3 - Yellow
      • L - Black
      Ask FixBot
    7. Ceiling Fan Pull Chain Switch Replacement: step 7, image 1 of 1
      • Attach the colored wires to the new switch's respective terminals.
      Ask FixBot
    8. Ceiling Fan Pull Chain Switch Replacement: step 8, image 1 of 2 Ceiling Fan Pull Chain Switch Replacement: step 8, image 2 of 2
      • Put back the switch in the hole in the fan housing from the inside.
      • Tighten up the screws on the outside.
      Ask FixBot
    9. Ceiling Fan Pull Chain Switch Replacement: step 9, image 1 of 3 Ceiling Fan Pull Chain Switch Replacement: step 9, image 2 of 3 Ceiling Fan Pull Chain Switch Replacement: step 9, image 3 of 3
      • Put back the white cover and then tighten up the nut at the bottom of the cover from where the chain is hanging.
      Ask FixBot
    10. Ceiling Fan Pull Chain Switch Replacement: step 10, image 1 of 2 Ceiling Fan Pull Chain Switch Replacement: step 10, image 2 of 2
      • Turn the power back on and test the switch to find if it is working or not.
      Ask FixBot
Finish Line
4 other people completed this guide.
Author
with
Berkeli Alashov
262 Reputation
1 Guide authored
1 Guide Comment
I'd recommend adding wire caps to the wires and also black tape.
Richard D - Reply Share
Past 24 Hours: 25
Past 7 Days: 208
Past 30 Days: 727
All Time: 21,755
