Up to 20% off select tools
Ceiling Fan Light Fixture Replacement
Views: 38K
View statistics:
Past 24 Hours:
11
Past 7 Days:
91
Past 30 Days:
422
All Time:
38,431
Comments: 11
11 guide comments.
Go to guide comments
Completed: 12
12 people have marked this guide "completed." Will you be next?
Favorites: 19
19 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
More than just a busted light bulb below your ceiling fan? Use this guide to replace the lighting fixture and restore the visual brilliance of your room.
    1. Ceiling Fan Light  Fixture Replacement, Light Fixture: step 1, image 1 of 3 Ceiling Fan Light  Fixture Replacement, Light Fixture: step 1, image 2 of 3 Ceiling Fan Light  Fixture Replacement, Light Fixture: step 1, image 3 of 3
      • Working with electrical wires could lead to electrocution.
      • Find your circuit breaker panel and turn off the breaker that corresponds to your ceiling lights.
      • Do this by pushing it to the right.
      • Also flip your light switch to off.
      Ask FixBot
    2. Ceiling Fan Light  Fixture Replacement: step 2, image 1 of 2 Ceiling Fan Light  Fixture Replacement: step 2, image 2 of 2
      • Remove the two 1.4 mm Phillips head screws that hold the fixture to the fan itself.
      • Once loose, pull down to expose the two connecting wires.
      Ask FixBot
    3. Ceiling Fan Light  Fixture Replacement: step 3, image 1 of 3 Ceiling Fan Light  Fixture Replacement: step 3, image 2 of 3 Ceiling Fan Light  Fixture Replacement: step 3, image 3 of 3
      • Disconnect these wires by twisting the caps in a counter-clockwise direction.
      • You only need to disconnect the wires coming from the lighting fixture.
      • Once both caps are removed, simply pull the wires apart to remove the fixture.
      Ask FixBot
    4. Ceiling Fan Light  Fixture Replacement: step 4, image 1 of 2 Ceiling Fan Light  Fixture Replacement: step 4, image 2 of 2
      • Loosen the nut holding the ceiling fan piece to the lighting fixture.
      • This step may require a crescent wrench if finger force is not enough.
      Ask FixBot
    5. Ceiling Fan Light  Fixture Replacement: step 5, image 1 of 1
      • Pull upwards to remove the fan piece that holds the light fixture.
      • Your model may require you to twist this piece in a counter-clockwise motion to remove.
      Ask FixBot
    6. Ceiling Fan Light  Fixture Replacement: step 6, image 1 of 1
      • Switch out the old fixture with your new fixture by doing the last two steps in reverse order.
      Ask FixBot
    7. Ceiling Fan Light  Fixture Replacement: step 7, image 1 of 2 Ceiling Fan Light  Fixture Replacement: step 7, image 2 of 2
      • To connect your new fixture, locate the black wire from your light and the colored wire from the fan.
      • Be sure to attached the colored wires to each other, and white wires to each other. (Positive-Positive, Negative-Negative)
      • Twist these together. Do the same with the two white wires.
      Ask FixBot
    8. Ceiling Fan Light  Fixture Replacement: step 8, image 1 of 2 Ceiling Fan Light  Fixture Replacement: step 8, image 2 of 2
      • Your new light fixture should come with replacement caps. Twist these in a clockwise motion over your wire ends to ensure connection.
      • The old caps work just as well for this if you were not given new ones.
      Ask FixBot
    9. Ceiling Fan Light  Fixture Replacement: step 9, image 1 of 1
      • Be sure to neatly tuck in all wires when re-attaching the fixture.
      • Failure to do this will result in not being able to correctly close the gap and put in the screws.
      Ask FixBot
    10. Ceiling Fan Light  Fixture Replacement: step 10, image 1 of 1
      • Flip your breaker back on, turn on your light switch, and enjoy your new lights!
      Ask FixBot
12 other people completed this guide.
Author
with
Garrett Janetzky
622 Reputation
1 Guide authored
Cal Poly, Team 14-1, Green Fall 2015 Member of Cal Poly, Team 14-1, Green Fall 2015
CPSU-GREEN-F15S14G1
4 Members
48 Guides authored
11 Guide Comments
Amazingly instructive, informative and concise. Brilliant.
Jeanie Bolin-Moore - Reply Share
It's awesome
Nandish Reddy - Reply Share
Just what I needed. Thanks.
bob.mohler - Reply Share
Does it have remote control??
ceiling fan manufacturers in india
Abhijeet Khole - Reply Share
Could someone provide the name of the light fixture used in the demonstration?
THOMAS DUFF - Reply Share
Past 24 Hours: 11
Past 7 Days: 91
Past 30 Days: 422
All Time: 38,431
