Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Spudger4.9
Place the phone screen-side down and place thumb on the yellow and black switch. Slide the switch to the right to unlock the back covering for removal.
With the back cover removed, locate and remove the Phillips screw pictured top-center, and the two torx screws above and to either side of the Phillips screw. A T-5 bit is required for removal of the torx screws.
WARNING: Proceeding beyond this point will void the warranty for this device.
Tool used on this step:Tweezers$4.99
Locate the camera module (pictured). To access the component to be replaced, the protective metal casing must first be removed. There are small gaps at each corner in which tweezers will fit. Choose any two, and slide this piece off.
The camera module will now easily pull free.
When installing the new camera module, be sure to resecure the brackets on either side. A faint click should also be heard when pressing the new piece into its socket. These are the tabs hooking onto the brackets, and will signify it is in securely.
3 other people completed this guide.
