Cassida Counterfeit Detector Motor Band Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
13
Past 30 Days:
58
All Time:
466
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Better Introduction
Improve this guide by completing or revising its introduction.
Parts
Tools
    1. Cassida Counterfeit Detector Motor Band Replacement, Cassida Counterfeit Detector: step 1, image 1 of 1
      • Remove the rubber legs.
      Ask FixBot
    2. Cassida Counterfeit Detector Motor Band Replacement: step 2, image 1 of 1
      • Using a Phillips #1 bit, remove the circled screws.
      Ask FixBot
    3. Cassida Counterfeit Detector Motor Band Replacement: step 3, image 1 of 1
      • Pry the top cover off, starting from the side with the switch, with a metal spudger.
      Ask FixBot
    4. Cassida Counterfeit Detector Motor Band Replacement: step 4, image 1 of 1
      • Pop the 4 tabs on the top of the machine up with a metal spudger and then remove the 2 side panels.
      Ask FixBot
    5. Cassida Counterfeit Detector Motor Band Replacement: step 5, image 1 of 1
      • Disconnect the wires circled and then remove the top section from the bottom section just by pulling the top section straight up and holding onto the bottom.
      Ask FixBot
    6. Cassida Counterfeit Detector Motor Band Replacement: step 6, image 1 of 1
      • All the parts disassembled.
      Ask FixBot
    1. Cassida Counterfeit Detector Motor Band Replacement, Motor Band: step 7, image 1 of 1
      • This is the band you will be replacing. If it is broken or loose, remove from the device completely.
      Ask FixBot
    2. Cassida Counterfeit Detector Motor Band Replacement: step 8, image 1 of 1
      • Install new band by placing it around the small grey pulley and then working it around the larger black pulley.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 58
All Time: 466
