Up to 20% off select tools
Cassida Counterfeit Detector Disassembly
View statistics:
Past 24 Hours:
3
Past 7 Days:
14
Past 30 Days:
77
All Time:
752
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Cassida Counterfeit Detector Disassembly, Cassida Counterfeit Detector: step 1, image 1 of 1
      • Remove the rubber legs.
      Ask FixBot
    2. Cassida Counterfeit Detector Disassembly: step 2, image 1 of 1
      • Using a Phillips #1 bit, remove the circled screws.
      Ask FixBot
    3. Cassida Counterfeit Detector Disassembly: step 3, image 1 of 1
      • Pry the top cover off, starting from the side with the switch, with a metal spudger.
      Ask FixBot
    4. Cassida Counterfeit Detector Disassembly: step 4, image 1 of 1
      • Pop the 4 tabs on the top of the machine up with a metal spudger and then remove the 2 side panels.
      Ask FixBot
    5. Cassida Counterfeit Detector Disassembly: step 5, image 1 of 1
      • Disconnect the wires circled and then remove the top section from the bottom section just by pulling the top section straight up and holding onto the bottom.
      Ask FixBot
    6. Cassida Counterfeit Detector Disassembly: step 6, image 1 of 1
      • All the parts disassembled.
      Ask FixBot
2 other people completed this guide.
Author
with
TREVOR j NELMS
543 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 77
All Time: 752
