Up to 20% off select tools
Casio fx-9750GII Screen Replacement
Views: 5.8K
View statistics:
Past 24 Hours:
6
Past 7 Days:
32
Past 30 Days:
207
All Time:
5,779
Comments: 2
2 guide comments.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 25 - 45 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will walk you through step-by-step instructions on how to change a broken or damaged screen of your Casio fx-9750GII graphing calculator.
A display screen shows the output of what is being input into the device through the keys. A damaged screen would display distorted prints from the calculator.
Before beginning this repair, make sure to take out the DC batteries at the back of the graphing calculator. Take extra precaution if screen appears to be shattered or broken. Put on rubber gloves to protect your hands if needed.
    1. Casio fx-9750GII Screen Replacement, Screen: step 1, image 1 of 2 Casio fx-9750GII Screen Replacement, Screen: step 1, image 2 of 2
      • Turn off the calculator and flip it over so the backside is facing up.
      • Slide the battery door off and remove all of the batteries.
      Ask FixBot
    2. Casio fx-9750GII Screen Replacement: step 2, image 1 of 1
      • Use a screwdriver to remove the screws from the back of the calculator.
      Ask FixBot
    3. Casio fx-9750GII Screen Replacement: step 3, image 1 of 1
      • Carefully remove the screw from the battery slot.
      Ask FixBot
    4. Casio fx-9750GII Screen Replacement: step 4, image 1 of 2 Casio fx-9750GII Screen Replacement: step 4, image 2 of 2
      • Remove the back case from the calculator.
      • Be careful of the spring that shows in the second picture. The spring is the convertor of the battery.
      Ask FixBot
    5. Casio fx-9750GII Screen Replacement: step 5, image 1 of 2 Casio fx-9750GII Screen Replacement: step 5, image 2 of 2
      • Remove the screws from the motherboard.
      Ask FixBot
    6. Casio fx-9750GII Screen Replacement: step 6, image 1 of 2 Casio fx-9750GII Screen Replacement: step 6, image 2 of 2
      Tool used on this step:
      Buy
      • Separate the screen cable from the motherboard using tweezers.
      • Remove the calculator screen.
      • Replace the screen.
      Ask FixBot
    7. Casio fx-9750GII Screen Replacement: step 7, image 1 of 2 Casio fx-9750GII Screen Replacement: step 7, image 2 of 2
      • Replace the board and back cover of the calculator, then install the batteries to test if the new screen works well.
      Ask FixBot
Author
with
YORK-CHEN-F21SEG[2]
145 Reputation
1 Guide authored
2 Guide Comments
thanks for the short description and pics. my screen cable appears to be soldered directly. I would help if you said more than "separate the screen cable from the motherboard" Perhaps add another pic or two of just that description? Are you breaking the wires? are you soldering on the new replacement board? are you taking off just the screen from that main 'calculator' electronics board?
Happy Zahn - Reply Share
Where to get the new replacement screen?
Ahmed Farhat - Reply Share
Past 24 Hours: 6
Past 7 Days: 32
Past 30 Days: 207
All Time: 5,779
