Casio fx-82MS Teardown
Views: 13K
View statistics:
Past 24 Hours:
12
Past 7 Days:
92
Past 30 Days:
359
All Time:
13,243
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 15
15 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
This iconic school calculator really needed to be torn apart.
Tools
    1. Casio fx-82MS Teardown, Remove Case Screws: step 1, image 1 of 3 Casio fx-82MS Teardown, Remove Case Screws: step 1, image 2 of 3 Casio fx-82MS Teardown, Remove Case Screws: step 1, image 3 of 3
      • Remove these screws.
      • 6x Philips #0
      Ask FixBot
    2. Casio fx-82MS Teardown, Split the halves: step 2, image 1 of 3 Casio fx-82MS Teardown, Split the halves: step 2, image 2 of 3 Casio fx-82MS Teardown, Split the halves: step 2, image 3 of 3
      Tool used on this step:
      Buy
      • Put the tweezers (in their closed state) into the indentations on the side of the calculator.
      • Slowly open the tweezers, to split the calculator into two halves.
      • On certain build batches of this calculator, glue was used to better hold the halves together. You might have to use a card to split the two pieces.
      Ask FixBot
    3. Casio fx-82MS Teardown, Remove PCB Screws: step 3, image 1 of 2 Casio fx-82MS Teardown, Remove PCB Screws: step 3, image 2 of 2
      • Remove these screws:
      • 4x Philips #0
      Ask FixBot
    4. Casio fx-82MS Teardown, Remove battery terminals from casing: step 4, image 1 of 2 Casio fx-82MS Teardown, Remove battery terminals from casing: step 4, image 2 of 2
      • Use a pair of tweezers to pull the connector out of its holder.
      • Use a screwdriver to lever the connector out of its housing.
      Ask FixBot
    5. Casio fx-82MS Teardown, Remove PCB from case: step 5, image 1 of 3 Casio fx-82MS Teardown, Remove PCB from case: step 5, image 2 of 3 Casio fx-82MS Teardown, Remove PCB from case: step 5, image 3 of 3
      • Insert a spudger in between the PCB and the rubber button holder.
      • Carefully remove the PCB and make sure not to damage the LCD ribbon cable.
      Ask FixBot
    6. Casio fx-82MS Teardown, Remove button holder: step 6, image 1 of 3 Casio fx-82MS Teardown, Remove button holder: step 6, image 2 of 3 Casio fx-82MS Teardown, Remove button holder: step 6, image 3 of 3
      • Peel off the rubber button holder starting in the top left corner.
      Ask FixBot
    7. Casio fx-82MS Teardown, Part List: step 7, image 1 of 2 Casio fx-82MS Teardown, Part List: step 7, image 2 of 2
      • Back part of the case.
      • Front face of the case.
      • PCB with LCD and battery terminals.
      • Rubber button holder.
      • Buttons.
      Ask FixBot
Finish Line
15 other people completed this guide.
Luca Casonato
571 Reputation
1 Guide authored
1 Guide Comment
I veganlover loved this guide although it isn’t vegan enough.
Alex Goodwin - Reply Share
Past 24 Hours: 12
Past 7 Days: 92
Past 30 Days: 359
All Time: 13,243
