Tools
Spudger4.9
Introduction
Go to step 1 ↓The Casio fx-82MS is a commonly used simple calculator in many schools. It has a very long lifetime. But sometimes a button stops working, which can be very annoying. In this guide we will guide you through the steps to fix this problem.
This is the calculator in question.
The tools you will need are: a Phillips screwdriver, a spudger and a soldering iron.
Locate the rubber contact points.
Solder the rubber contact points, while using the spudger to pry the PCB loose.
Start with the lower plugs (left on the photo). Gently pry the PCB loose at the same time.
If you don't have accessibility to a solder iron, use a utility knife to remove the plugs.
2 other people completed this guide.
