Casio fx-580VNX Battery Replacement
    1. Casio fx-580VNX  Battery Replacement, Operate Shift+OFF key: step 1, image 1 of 1
      • Before replacing the battery, turn off the computer first by pressing [Shift] and then [AC] key.
      • Do not replace the battery when it is on. If you do it, it maybe have a battery risk.
      Ask FixBot
    2. Casio fx-580VNX  Battery Replacement, Remove 6 Philips Screw: step 2, image 1 of 1
      • Remove 6 Philips screw to take the cover off.
      Ask FixBot
    3. Casio fx-580VNX  Battery Replacement, Open the case: step 3, image 1 of 1
      • Carefully remove the case or the cover. Don't use too much force.
      Ask FixBot
    4. Casio fx-580VNX  Battery Replacement, Remove The Battery: step 4, image 1 of 1
      • Remove the old battery from the computer.
      Ask FixBot
    5. Casio fx-580VNX  Battery Replacement, Battery removed: step 5, image 1 of 1
      • The old battery have removed. You can replace with the new battery.
      Ask FixBot
Before you use the calculator after replacing, operate the key: Shift+9(Reset), press 3 then press =.
2 other people completed this guide.
Nazomi Inc
1,440 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 77
All Time: 3,006
