Up to 20% off select tools
Casio WK-220 Buttons Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
4
Past 7 Days:
17
Past 30 Days:
91
All Time:
1,446
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 hour
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will show you how to remove, clean, and replace the button clusters on the keyboard's front black panel
    1. Casio WK-220 Buttons Replacement, Buttons: step 1, image 1 of 2 Casio WK-220 Buttons Replacement, Buttons: step 1, image 2 of 2
      • Place keyboard key side down
      • Remove 23 16mm screws with Phillips #2 screwdriver
      Ask FixBot
    2. Casio WK-220 Buttons Replacement: step 2, image 1 of 2 Casio WK-220 Buttons Replacement: step 2, image 2 of 2
      • Use plastic opening tool to pry up volume knob
      • Remove volume knob
      Ask FixBot
    3. Casio WK-220 Buttons Replacement: step 3, image 1 of 3 Casio WK-220 Buttons Replacement: step 3, image 2 of 3 Casio WK-220 Buttons Replacement: step 3, image 3 of 3
      • Pull black panel away from keyboard and place face-up on keys
      • Remove all screws from circuit panel with Phillips #1 and #2 screwdrivers in order to remove all 18 16mm and 18mm screws.
      Ask FixBot
    4. Casio WK-220 Buttons Replacement: step 4, image 1 of 3 Casio WK-220 Buttons Replacement: step 4, image 2 of 3 Casio WK-220 Buttons Replacement: step 4, image 3 of 3
      • Pull circuit panel away from black panel
      • Set circuit panel out of the way
      • Remove/clean button cluster
      • Reassemble with new/cleaned button cluster
      Ask FixBot
Author
with
Alexa
705 Reputation
6 Guides authored
Cal Poly, Team 10-2, Banghart Winter 2017 Member of Cal Poly, Team 10-2, Banghart Winter 2017
CPSU-BANGHART-W17S10G2
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 91
All Time: 1,446
