Casio LK-170 Battery Replacement
Views: 1.8K
View statistics:
Past 24 Hours:
2
Past 7 Days:
18
Past 30 Days:
103
All Time:
1,792
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 3 - 5 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
Changing the battery will be quite simple. All you need to do is pull the tab.
    1. Casio LK-170 Battery Replacement, Battery: step 1, image 1 of 2 Casio LK-170 Battery Replacement, Battery: step 1, image 2 of 2
      • Locate the battery compartment on the back of the keyboard. The compartment is characterized as a small black square.
      Ask FixBot
    2. Casio LK-170 Battery Replacement: step 2, image 1 of 1
      • Use your finger to push down with a small amount of pressure on the tab protruding from the top of the battery compartment.
      • Remove this compartment cover carefully with your hand to completely to reveal the batteries in the compartment.
      Ask FixBot
    3. Casio LK-170 Battery Replacement: step 3, image 1 of 2 Casio LK-170 Battery Replacement: step 3, image 2 of 2
      • Pry all 6 batteries from the compartment using your thumb or index finger.
      • Make sure to remove the AA batteries from the positive side.
      Ask FixBot
Samantha Baker
443 Reputation
4 Guides authored
Cal Poly, Team 13-2, Banghart Winter 2017 Member of Cal Poly, Team 13-2, Banghart Winter 2017
CPSU-BANGHART-W17S13G2
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 103
All Time: 1,792
