Casio FX-991EX Battery Replacement
    1. Casio FX-991EX Battery Replacement, Remove the battery cover: step 1, image 1 of 2 Casio FX-991EX Battery Replacement, Remove the battery cover: step 1, image 2 of 2
      • Remove the battery cover's screw using a Philips #0 screwdriver.
      Ask FixBot
    2. Casio FX-991EX Battery Replacement, Remove the battery: step 2, image 1 of 2 Casio FX-991EX Battery Replacement, Remove the battery: step 2, image 2 of 2
      • Use a spudger to remove the battery using the gap to the right.
      • Don't use sharp objects that may cause harm or damage. The battery can be hard to pop out, but will do so. Dispose of a damaged battery via an e-waste collection site.
      Ask FixBot
    3. Casio FX-991EX Battery Replacement, Replace the battery: step 3, image 1 of 2 Casio FX-991EX Battery Replacement, Replace the battery: step 3, image 2 of 2
      • The FX-991EX uses a 1.5V LR44 battery.
      • Slot the new battery into the compartment. Ensure that the positive side (with writing) faces up...
      • And the negative side faces the calculator's screen.
      Ask FixBot
    4. Casio FX-991EX Battery Replacement, Screw the cover back on: step 4, image 1 of 1
      • Slot the battery cover back on and screw it down.
      Ask FixBot
If you need to reset the calculator after this, it's SHIFT+9 > 3 > =.
Otherwise, you're ready to crunch numbers again!
9 other people completed this guide.
FarmYard Gaming
2,225 Reputation
1 Guide authored
4 Guide Comments
Just discovered during a lecture that my battery has become a spicy pillow - if you're leaving this in storage be careful and monitor it, lest it explode and/or warp the case irreparably.
FarmYard Gaming - Reply Share
Which size of screws
李生山 - Reply Share
I found nothing in the slot. What can i do?
UTL Shaion - Reply Share
Do you see any wires connecting the battery to the circuit board? I don’t see any on mine. Both of ours may be fake lmao
Ivan Liu - Reply Share
Past 24 Hours: 14
Past 7 Days: 142
Past 30 Days: 598
All Time: 28,757
