Casio FX-115MS Motherboard and Screen Replacement
  1. Casio FX-115MS Motherboard and Screen Replacement, Back Plate: step 1, image 1 of 1
    • Remove the 6 screws, which are 5mm long, using a PH1 screwdriver.
    Ask FixBot
  2. Casio FX-115MS Motherboard and Screen Replacement: step 2, image 1 of 3 Casio FX-115MS Motherboard and Screen Replacement: step 2, image 2 of 3 Casio FX-115MS Motherboard and Screen Replacement: step 2, image 3 of 3
    • Use plastic spudger to separate backplate from the front-plate. Place the flat end of the spudger in the seam between the front and back, near one end of the calculator. Then slide the spudger towards the calculator's center. The two sides will pop free from each other as you go through it with the spudger.
    Ask FixBot
  3. Casio FX-115MS Motherboard and Screen Replacement, Battery: step 3, image 1 of 2 Casio FX-115MS Motherboard and Screen Replacement, Battery: step 3, image 2 of 2
    • Using the pointed end of the nylon spudger, carefully pry an edge of the battery, and lift the battery from its socket.
    Ask FixBot
  4. Casio FX-115MS Motherboard and Screen Replacement, Motherboard and Screen: step 4, image 1 of 2 Casio FX-115MS Motherboard and Screen Replacement, Motherboard and Screen: step 4, image 2 of 2
    • Using the plastic spudger, carefully pry the battery terminals from the front plate. If the plastic spudger is too weak for prying out the terminals, use the small metal spudger.By Carefully bending and/or prying the little teeth on the terminals upwards you can easily remove them.
    Ask FixBot
  5. Casio FX-115MS Motherboard and Screen Replacement: step 5, image 1 of 3 Casio FX-115MS Motherboard and Screen Replacement: step 5, image 2 of 3 Casio FX-115MS Motherboard and Screen Replacement: step 5, image 3 of 3
    • Using the small metal spudger. Carefully pry around the edge of the solar panel until it becomes loose. Then simply pull it from its socket using your hands.
    Ask FixBot
  6. Casio FX-115MS Motherboard and Screen Replacement: step 6, image 1 of 2 Casio FX-115MS Motherboard and Screen Replacement: step 6, image 2 of 2
    • Using a PH0 phillips screwdriver, unscrew the four, 4mm, pan head screws from the motherboard.
    Ask FixBot
  7. Casio FX-115MS Motherboard and Screen Replacement: step 7, image 1 of 3 Casio FX-115MS Motherboard and Screen Replacement: step 7, image 2 of 3 Casio FX-115MS Motherboard and Screen Replacement: step 7, image 3 of 3
    • Carefully lift the motherboard, screen, solar panel, and battery terminal combination from the front plate. Start from the motherboard and lift at an angle toward the solar panel.
    Ask FixBot
9 other people completed this guide.
Lindsey Griffin
472 Reputation
3 Guides authored
USF Tampa, Team 2-2, Nance Fall 2016 Member of USF Tampa, Team 2-2, Nance Fall 2016
USFT-NANCE-F16S2G2
4 Members
15 Guides authored
1 Guide Comment
where can i find an lcd for this exact calculator?
Ahmad Alsabbagh - Reply Share
Past 24 Hours: 5
Past 7 Days: 20
Past 30 Days: 91
All Time: 4,509
