Up to 20% off select tools
Casio FX-115MS Battery Replacement
Views: 11K
View statistics:
Past 24 Hours:
9
Past 7 Days:
53
Past 30 Days:
211
All Time:
10,892
Comments: 4
1 comment on steps, 3 guide comments.
Go to guide comments
Completed: 8
8 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
In the event that your battery dies, you will need to replace it. This guide will show you how.
    1. Casio FX-115MS Battery Replacement, Back Plate: step 1, image 1 of 1
      • Remove the 6 screws, which are 5mm long, using a PH1 screwdriver.
      Ask FixBot
    2. Casio FX-115MS Battery Replacement: step 2, image 1 of 3 Casio FX-115MS Battery Replacement: step 2, image 2 of 3 Casio FX-115MS Battery Replacement: step 2, image 3 of 3
      • Use plastic spudger to separate backplate from the front-plate. Place the flat end of the spudger in the seam between the front and back, near one end of the calculator. Then slide the spudger towards the calculator's center. The two sides will pop free from each other as you go through it with the spudger.
      Ask FixBot
    1. Casio FX-115MS Battery Replacement, Battery: step 3, image 1 of 2 Casio FX-115MS Battery Replacement, Battery: step 3, image 2 of 2
      • Using the pointed end of the nylon spudger, carefully pry an edge of the battery, and lift the battery from its socket.
      Ask FixBot
8 other people completed this guide.
Author
with
Lindsey Griffin
472 Reputation
3 Guides authored
USF Tampa, Team 2-2, Nance Fall 2016 Member of USF Tampa, Team 2-2, Nance Fall 2016
USFT-NANCE-F16S2G2
4 Members
60 Guides authored
3 Guide Comments
I just wanted to be sure that using a spudger wouldn't damage anything inside before actually trying it; this quick guide comfirmed it would be OK. However, I found I had to pry from the gap you can open by hand after removing the screws, rather than from the end as suggested in the guide. Maybe it's different for the version with five screws (from about the year 2005), which I have, instead of the illustrated version with six screws.
Andrew Morton - Reply Share
What size or type of battery does it take? It would be nice to have it on hand before prying it apart. Thanks-
Norman Timbs Jr - Reply Share
Thanks for the guide. Actually, I could use my finger nail to pry it open. It is not that hard after removing the screws.
Martian - Reply Share
Past 24 Hours: 9
Past 7 Days: 53
Past 30 Days: 211
All Time: 10,892
