Casio FX-115ES PLUS Battery Replacement
Views: 4.8K
View statistics:
Past 24 Hours:
2
Past 7 Days:
28
Past 30 Days:
156
All Time:
4,835
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Welcome to our guide on replacing the battery for a Casio FX-115ES PLUS calculator! Over time, the battery in your calculator may start to wear down and lose its ability to hold a charge, which can result in your calculator not functioning properly. Fortunately, replacing the battery is a quick and simple process that can be done at home with just a few tools and some basic knowledge. In this guide, we will walk you through each step of the process, providing detailed instructions and helpful tips to ensure a successful battery replacement. Whether you are an experienced DIY-er or a first time battery replacer, this guide is designed to help you get your Casio FX115ES PLUS calculator back up and running in no time. So lets get started!
Tools
  • Phillips #0 Screwdriver
    5
  • Spudger
    4.9
    1. Casio FX-115ES PLUS Battery Replacement, Battery: step 1, image 1 of 1
      • Turn off the calculator by pressing the [shift] button.
      • Press the [AC] [OFF] button to turn off the calculator by pressing the [shift] button.
      Ask FixBot
    2. Casio FX-115ES PLUS Battery Replacement: step 2, image 1 of 3 Casio FX-115ES PLUS Battery Replacement: step 2, image 2 of 3 Casio FX-115ES PLUS Battery Replacement: step 2, image 3 of 3
      • Turn the calculator the other way around so that the small panel in the top right corner of the back of the calculator faces forward.
      • Use a Phillips #0 screwdriver to remove the screw in the upper right corner.
      • Don't force the screwdriver on the screw, as it can strip the screw
      Ask FixBot
    3. Casio FX-115ES PLUS Battery Replacement: step 3, image 1 of 1
      • Remove the battery cover.
      Ask FixBot
    4. Casio FX-115ES PLUS Battery Replacement: step 4, image 1 of 1
      • Insert the spudger in the available slot in the middle of the right side.
      • Use the spudger to take the battery out carefully.
      • Be careful when removing the battery to avoid any damage.
      Ask FixBot
    5. Casio FX-115ES PLUS Battery Replacement: step 5, image 1 of 1
      • Place the new 357 oxide button battery into the calculator.
      • Make sure that the + sign is at the bottom.
      Ask FixBot
    6. Casio FX-115ES PLUS Battery Replacement: step 6, image 1 of 3 Casio FX-115ES PLUS Battery Replacement: step 6, image 2 of 3 Casio FX-115ES PLUS Battery Replacement: step 6, image 3 of 3
      • Reattach the battery cover.
      • Insert the screw back in place along with the cover using a Phillips #0 screwdriver.
      • Make sure to turn the screwdriver clockwise to lock the screw in tight, preventing the battery from falling out.
      Ask FixBot
    7. Casio FX-115ES PLUS Battery Replacement: step 7, image 1 of 1
      • Reset the calculator by pressing [ON].
      • Press the [Shift] button.
      • Press the [9] [CLR] button to clear the data.
      • Press the [3] [ALL] button option.
      • Press the [=] [yes] button to accept.
      • Press the [AC] key to reset completely.
      Ask FixBot
You have successfully replaced a Casio FX-115ES PLUS battery
Rodrigo Lopez
145 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 28
Past 30 Days: 156
All Time: 4,835
