Casio Exilim EX-Z850 Outer Case Replacement
  1. Casio Exilim EX-Z850 Outer Case Replacement, Outer Case: step 1, image 1 of 3 Casio Exilim EX-Z850 Outer Case Replacement, Outer Case: step 1, image 2 of 3 Casio Exilim EX-Z850 Outer Case Replacement, Outer Case: step 1, image 3 of 3
    • Remove all four screws on the camera's side using a Phillips #00 screwdriver.
    • Remove all four screws on the opposite side of the camera using the same screwdriver.
    • Remove all four screws on the bottom of the camera using the same screwdriver.
    • The bottom screws are longer than the top screws, so label them accordingly for easy reassembly.
    Ask FixBot
  2. Casio Exilim EX-Z850 Outer Case Replacement: step 2, image 1 of 3 Casio Exilim EX-Z850 Outer Case Replacement: step 2, image 2 of 3 Casio Exilim EX-Z850 Outer Case Replacement: step 2, image 3 of 3
    Tool used on this step:
    Buy
    • Pry open the bottom casing.
    • Remove the ribbon from the LCD screen using the tweezers and set aside the bottom casing.
    • These steps should be taken carefully in order to prevent damage to the camera.
    Ask FixBot
  3. Casio Exilim EX-Z850 Outer Case Replacement: step 3, image 1 of 2 Casio Exilim EX-Z850 Outer Case Replacement: step 3, image 2 of 2
    • Pry apart the top casing using tweezers.
    • Remove the top casing from the camera and set aside the top casing.
    Ask FixBot
To reassemble your device, follow these instructions in reverse order, starting with reattaching the top casing.
2 other people completed this guide.
Logan
313 Reputation
2 Guides authored
Cal Poly, Team 4-38, Regan Winter 2011 Member of Cal Poly, Team 4-38, Regan Winter 2011
CPSU-REGAN-W11S4G38
4 Members
14 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 40
All Time: 3,524
