Casio Exilim EX-Z850 Motherboard Replacement
  1. Casio Exilim EX-Z850 Motherboard Replacement, Motherboard: step 1, image 1 of 1
    • Using the Phillips #00 screwdriver, remove the four screws from the side of the speaker.
    Ask FixBot
  2. Casio Exilim EX-Z850 Motherboard Replacement: step 2, image 1 of 1
    • Using the Phillips #00 screwdriver, remove the four long screws from the bottom of the camera.
    • When reassembling the camera, the longer screws go on the bottom of the camera.
    Ask FixBot
  3. Casio Exilim EX-Z850 Motherboard Replacement: step 3, image 1 of 1
    • Using the Phillips #00 screwdriver, remove the four screws from the side opposite of the speaker.
    Ask FixBot
  4. Casio Exilim EX-Z850 Motherboard Replacement: step 4, image 1 of 3 Casio Exilim EX-Z850 Motherboard Replacement: step 4, image 2 of 3 Casio Exilim EX-Z850 Motherboard Replacement: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • Pry open bottom casing gently after all screws have been removed.
    • With tweezers, carefully remove the ribbon from the LCD screen.
    • Set the bottom casing aside.
    Ask FixBot
  5. Casio Exilim EX-Z850 Motherboard Replacement: step 5, image 1 of 3 Casio Exilim EX-Z850 Motherboard Replacement: step 5, image 2 of 3 Casio Exilim EX-Z850 Motherboard Replacement: step 5, image 3 of 3
    • Pry apart the top casing using tweezers.
    • Set the top casing aside.
    • The bottom left screw on the board is orange and the longest screw.
    Ask FixBot
  6. Casio Exilim EX-Z850 Motherboard Replacement: step 6, image 1 of 2 Casio Exilim EX-Z850 Motherboard Replacement: step 6, image 2 of 2
    • Carefully remove the pieces of black tape on the bottom of the LCD screen that attach it to the frame.
    • Use tweezers to pry the LCD screen off from the opening.
    Ask FixBot
  7. Casio Exilim EX-Z850 Motherboard Replacement: step 7, image 1 of 2 Casio Exilim EX-Z850 Motherboard Replacement: step 7, image 2 of 2
    • Lift the LCD screen and move it to the other side.
    Ask FixBot
  8. Casio Exilim EX-Z850 Motherboard Replacement: step 8, image 1 of 2 Casio Exilim EX-Z850 Motherboard Replacement: step 8, image 2 of 2
    • Using a pair of tweezers, pry off the LCD casing.
    Ask FixBot
  9. Casio Exilim EX-Z850 Motherboard Replacement: step 9, image 1 of 3 Casio Exilim EX-Z850 Motherboard Replacement: step 9, image 2 of 3 Casio Exilim EX-Z850 Motherboard Replacement: step 9, image 3 of 3
    • Flip open the connector holding the ribbon.
    • Use the tweezers to carefully pull out the LCD screen with the ribbon from the camera.
    Ask FixBot
  10. Casio Exilim EX-Z850 Motherboard Replacement: step 10, image 1 of 2 Casio Exilim EX-Z850 Motherboard Replacement: step 10, image 2 of 2
    • Using the Phillips #00 screwdriver, remove two screws on the side where the battery is located.
    • Remove the lanyard loop after the screws come off.
    • Pull the side casing so it becomes dislocated from the top of the camera frame.
    Ask FixBot
  11. Casio Exilim EX-Z850 Motherboard Replacement: step 11, image 1 of 2 Casio Exilim EX-Z850 Motherboard Replacement: step 11, image 2 of 2
    • On the front of the camera near the flash, flip the connector holding the ribbon.
    • Remove the ribbon from the connector.
    Ask FixBot
  12. Casio Exilim EX-Z850 Motherboard Replacement: step 12, image 1 of 3 Casio Exilim EX-Z850 Motherboard Replacement: step 12, image 2 of 3 Casio Exilim EX-Z850 Motherboard Replacement: step 12, image 3 of 3
    • Carefully remove the L-shaped frame from the camera.
    • The L shaped frame is being held in by two plastic bumps and a metal tab at the bottom of the camera.
    • Pop the frame off the bumps and tabs.
    • Potential for device damage: Be careful not to pull off the yellow and orange wire soldered onto the camera.
    Ask FixBot
  13. Casio Exilim EX-Z850 Motherboard Replacement: step 13, image 1 of 2 Casio Exilim EX-Z850 Motherboard Replacement: step 13, image 2 of 2
    • Flip the connector and remove the ribbon cable from the motherboard next to the lens.
    Ask FixBot
  14. Casio Exilim EX-Z850 Motherboard Replacement: step 14, image 1 of 2 Casio Exilim EX-Z850 Motherboard Replacement: step 14, image 2 of 2
    • Remove the frame on the back side of the camera where the LCD screen was.
    • Use the Phillips #00 screwdriver to remove the two screws connecting the frame to the camera.
    • Slowly pry off the frame from the camera.
    • After removing the frame, a plastic piece with two yellow buttons should fall off.
    • Do not pull the plastic piece off as it is soldered to two wires: a yellow and orange one.
    Ask FixBot
  15. Casio Exilim EX-Z850 Motherboard Replacement: step 15, image 1 of 1
    • On the back of the camera where the LCD screen was, remove the 3 screws located behind the lens using the Phillips #00 screwdriver.
    Ask FixBot
  16. Casio Exilim EX-Z850 Motherboard Replacement: step 16, image 1 of 1
    • Remove the large orange ribbon previously held in by screws from the camera.
    Ask FixBot
  17. Casio Exilim EX-Z850 Motherboard Replacement: step 17, image 1 of 1
    • On the backside of the camera where the indicator lamp is located, remove the two screws using the Phillips #00 screwdriver.
    Ask FixBot
  18. Casio Exilim EX-Z850 Motherboard Replacement: step 18, image 1 of 3 Casio Exilim EX-Z850 Motherboard Replacement: step 18, image 2 of 3 Casio Exilim EX-Z850 Motherboard Replacement: step 18, image 3 of 3
    • On the front side of the indicator lamp remove the screw using the Phillips #00 screwdriver.
    Ask FixBot
  19. Casio Exilim EX-Z850 Motherboard Replacement: step 19, image 1 of 2 Casio Exilim EX-Z850 Motherboard Replacement: step 19, image 2 of 2
    • Desolder the lens from the motherboard.
    • Desolder the wire from the motherboard.
    • The motherboard is now detached from the rest of the camera.
    Ask FixBot
Jennifer Roth
162 Reputation
1 Guide authored
Cal Poly, Team 4-38, Regan Winter 2011 Member of Cal Poly, Team 4-38, Regan Winter 2011
CPSU-REGAN-W11S4G38
4 Members
14 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 38
All Time: 4,468
