Casio Exilim EX-Z80 Back and Front Cover Replacement
  1. Casio Exilim EX-Z80 Back and Front Cover Replacement, Battery: step 1, image 1 of 2 Casio Exilim EX-Z80 Back and Front Cover Replacement, Battery: step 1, image 2 of 2
    • Locate the battery compartment at the bottom of the camera.
    • With your thumb, gently press down on the compartment door and slide to the left to open.
    Ask FixBot
  2. Casio Exilim EX-Z80 Back and Front Cover Replacement: step 2, image 1 of 2 Casio Exilim EX-Z80 Back and Front Cover Replacement: step 2, image 2 of 2
    • With your index finger, gently pull back gray release lever for the battery to pop out.
    • Gently pull the battery out of the slot.
    Ask FixBot
  3. Casio Exilim EX-Z80 Back and Front Cover Replacement, Back and Front Cover: step 3, image 1 of 3 Casio Exilim EX-Z80 Back and Front Cover Replacement, Back and Front Cover: step 3, image 2 of 3 Casio Exilim EX-Z80 Back and Front Cover Replacement, Back and Front Cover: step 3, image 3 of 3
    • Remove the four 3 mm black screws from the bottom of the camera using a Phillips #000 screwdriver.
    • Open the battery compartment with your thumb or index finger.
    • Remove the single 2 mm silver screw that is now exposed using a Phillips #000 screwdriver.
    Ask FixBot
  4. Casio Exilim EX-Z80 Back and Front Cover Replacement: step 4, image 1 of 3 Casio Exilim EX-Z80 Back and Front Cover Replacement: step 4, image 2 of 3 Casio Exilim EX-Z80 Back and Front Cover Replacement: step 4, image 3 of 3
    • Open the USB port tab.
    • Remove the single 2 mm silver screw using a Phillips #000 screwdriver.
    Ask FixBot
  5. Casio Exilim EX-Z80 Back and Front Cover Replacement: step 5, image 1 of 2 Casio Exilim EX-Z80 Back and Front Cover Replacement: step 5, image 2 of 2
    • Remove the two 2 mm silver screws using a Phillips #000 screwdriver.
    Ask FixBot
  6. Casio Exilim EX-Z80 Back and Front Cover Replacement: step 6, image 1 of 2 Casio Exilim EX-Z80 Back and Front Cover Replacement: step 6, image 2 of 2
    • Carefully remove the silver strip from left side. Open the battery cover and remove the metal strip with fingers by sliding it to the left.
    Ask FixBot
  7. Casio Exilim EX-Z80 Back and Front Cover Replacement: step 7, image 1 of 2 Casio Exilim EX-Z80 Back and Front Cover Replacement: step 7, image 2 of 2
    • With the metal spudger, pry out the edge of the silver strip at the bottom right side of the camera.
    • Carefully remove the remaining part of the metal strip.
    Ask FixBot
  8. Casio Exilim EX-Z80 Back and Front Cover Replacement: step 8, image 1 of 2 Casio Exilim EX-Z80 Back and Front Cover Replacement: step 8, image 2 of 2
    • Remove the two 2 mm silver screws from the top corners of the camera using a Phillips #000 screwdriver.
    • Remove the three 2 mm screws from the left side using a Phillips #000 screwdriver.
    Ask FixBot
  9. Casio Exilim EX-Z80 Back and Front Cover Replacement: step 9, image 1 of 3 Casio Exilim EX-Z80 Back and Front Cover Replacement: step 9, image 2 of 3 Casio Exilim EX-Z80 Back and Front Cover Replacement: step 9, image 3 of 3
    • Using a small opening tool carefully release all lock tabs at the top and on the side of the camera from their locked position.
    • Using your hands, carefully separate the front and back panel from the camera.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 28
All Time: 1,048
