Casio CZ-1000 Barrel Plug Replacement
  1. Casio CZ-1000 Barrel Plug Replacement, Backplate: step 1, image 1 of 2 Casio CZ-1000 Barrel Plug Replacement, Backplate: step 1, image 2 of 2
    • Use a Phillips #1 screwdriver to remove the eleven 7.5 mm screws securing the back plate.
    Ask FixBot
  2. Casio CZ-1000 Barrel Plug Replacement: step 2, image 1 of 3 Casio CZ-1000 Barrel Plug Replacement: step 2, image 2 of 3 Casio CZ-1000 Barrel Plug Replacement: step 2, image 3 of 3
    • Using a Phillips #1 screwdriver, remove all 14 5.5 mm screws from the two motherboards.
    • These screws secure the motherboards to the keyboard assembly and the dial on the right side.
    Ask FixBot
  3. Casio CZ-1000 Barrel Plug Replacement: step 3, image 1 of 3 Casio CZ-1000 Barrel Plug Replacement: step 3, image 2 of 3 Casio CZ-1000 Barrel Plug Replacement: step 3, image 3 of 3
    • Carefully cut the zip tie located in the right-hand corner using a pair of scissors or wire cutters.
    • Be sure to avoid cutting any nearby wires or components.
    • Gently slide all the plugs out of their sockets.
    • This will prevent them from catching on anything or damaging the connectors as you lift.
    Ask FixBot
  4. Casio CZ-1000 Barrel Plug Replacement, Barrel Plug: step 4, image 1 of 1
    • Clean the area around the barrel plug on the board using a lint-free cloth or a paper towel to remove dust or debris.
    • This ensures a clean working surface and better visibility of the solder joints.
    Ask FixBot
  5. Casio CZ-1000 Barrel Plug Replacement: step 5, image 1 of 2 Casio CZ-1000 Barrel Plug Replacement: step 5, image 2 of 2
    • Hold the soldering iron against the solder joint for a few seconds to melt it, then gently pull the barrel plug out while the solder is liquid.
    Ask FixBot
Jace Alexander
181 Reputation
2 Guides authored
Cuesta, Team 60-3, Krynen Fall 2024 Member of Cuesta, Team 60-3, Krynen Fall 2024
CUESTA-KRYNEN-F24S60G3
4 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 26
All Time: 290
