Casio CTK-501 Speaker Replacement
  1. Casio CTK-501 Speaker Replacement, Bottom Panel: step 1, image 1 of 2 Casio CTK-501 Speaker Replacement, Bottom Panel: step 1, image 2 of 2
    • Flip the keyboard over so that the bottom is facing up.
    • Remove the twenty-seven 12 mm screws from the dark-grey panel using a Phillips #2 screwdriver.
    Ask FixBot
  2. Casio CTK-501 Speaker Replacement: step 2, image 1 of 1
    • Remove the bottom panel by lifting and pulling it towards yourself.
    Ask FixBot
  3. Casio CTK-501 Speaker Replacement: step 3, image 1 of 2 Casio CTK-501 Speaker Replacement: step 3, image 2 of 2
    • Flip open the top half of the keyboard.
    • Set the keyboard onto the bottom half with the internal parts facing up.
    • Be careful not to let the bottom drop.
    Ask FixBot
  4. Casio CTK-501 Speaker Replacement, Speaker: step 4, image 1 of 1
    • Plug in the soldering iron and place somewhere safe to avoid burning yourself or causing a fire.
    • Completely unscrew and remove all four screws in the corners of the speaker.
    Ask FixBot
  5. Casio CTK-501 Speaker Replacement: step 5, image 1 of 1
    • Pull the speaker out of the keyboard and set on a flat surface to solder safely.
    Ask FixBot
  6. Casio CTK-501 Speaker Replacement: step 6, image 1 of 1
    • Be careful when removing the wires and avoid dripping solder on yourself or the keyboard.
    • Touch soldering iron to solder over the end of the wires, and when the solder melts, pull the wires away from the speaker.
    • Remove the speaker and replace with a new one.
    Ask FixBot
  7. Casio CTK-501 Speaker Replacement: step 7, image 1 of 1
    • Strip the wires if you need more clean metal to solder to the speaker.
    • Use the soldering iron to melt the solder over the wire to connect them to the speaker.
    Ask FixBot
  8. Casio CTK-501 Speaker Replacement: step 8, image 1 of 1
    • Completely screw in the screws back into the original positions on the corner of the speaker.
    Ask FixBot
Jimmy Winne
578 Reputation
6 Guides authored
Cal Poly, Team 9-16, Amido Fall 2012 Member of Cal Poly, Team 9-16, Amido Fall 2012
CPSU-AMIDO-F12S9G16
4 Members
6 Guides authored
1 Guide Comment
I have a Casio ctk 691 Keyboard and it’s not Turning up is working is coming on but my volume slider is not working
Jacameron Bussey - Reply Share
Past 24 Hours: 0
Past 7 Days: 16
Past 30 Days: 63
All Time: 7,133
