Casio CTK-501 LCD Screen Replacement
Views: 6.1K
View statistics:
Past 24 Hours:
0
Past 7 Days:
14
Past 30 Days:
98
All Time:
6,066
Comments: 4
1 comment on steps, 3 guide comments.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 20 minutes
Difficulty: Moderate
Missing Steps
Oops! This guide is currently missing one or more important steps.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Introduction
Go to step 1 ↓
At some point during the use of your Casio CTK-501, you might encounter a time where the LCD screen starts to malfunction or in some cases just stop working. With this guide we will help you get to the screen, and show you how to replace it so that the screen can work like new.
For this repair you will need a total of two things, a #2 Phillips head screwdriver, and two pieces of tape. If you're not sure if you have the right tools or if you're not sure where to get them, the links to both the tape and screwdriver have been provided.
Before starting on this guide, check again to see if the screen is working or not, power it on and off a couple times, and make sure it's connected to a power source. If the problem still persists and the screen isn't working, you can continue with the guide, but check and be sure that the device is completely powered off before starting to take it apart.
Tools
    1. Casio CTK-501 LCD Screen Replacement, Bottom Panel: step 1, image 1 of 2 Casio CTK-501 LCD Screen Replacement, Bottom Panel: step 1, image 2 of 2
      • Flip the keyboard over so that the bottom is facing up.
      • Remove the twenty-seven 12 mm screws from the dark-grey panel using a Phillips #2 screwdriver.
      Ask FixBot
    2. Casio CTK-501 LCD Screen Replacement: step 2, image 1 of 1
      • Remove the bottom panel by lifting and pulling it towards yourself.
      Ask FixBot
    3. Casio CTK-501 LCD Screen Replacement: step 3, image 1 of 2 Casio CTK-501 LCD Screen Replacement: step 3, image 2 of 2
      • Flip open the top half of the keyboard.
      • Set the keyboard onto the bottom half with the internal parts facing up.
      • Be careful not to let the bottom drop.
      Ask FixBot
    1. Casio CTK-501 LCD Screen Replacement, LCD Screen: step 4, image 1 of 1
      • Completely unscrew and remove all six of the screws on the central circuit board.
      Ask FixBot
    2. Casio CTK-501 LCD Screen Replacement: step 5, image 1 of 1
      • Lift the circuit board out of your way.
      Ask FixBot
    3. Casio CTK-501 LCD Screen Replacement: step 6, image 1 of 1
      • Remove tape from the LCD screen and remove the screen completely.
      Ask FixBot
    4. Casio CTK-501 LCD Screen Replacement: step 7, image 1 of 2 Casio CTK-501 LCD Screen Replacement: step 7, image 2 of 2
      • Replace the LCD screen and tape it down to the top cover.
      Ask FixBot
    5. Casio CTK-501 LCD Screen Replacement: step 8, image 1 of 1
      • Place the circuit board back on top of the LCD screen.
      • Screw all of the screws completely in their original positions.
      Ask FixBot
2 other people completed this guide.
Jimmy Winne
578 Reputation
6 Guides authored
Cal Poly, Team 9-16, Amido Fall 2012 Member of Cal Poly, Team 9-16, Amido Fall 2012
CPSU-AMIDO-F12S9G16
4 Members
72 Guides authored
3 Guide Comments
Where did you get the replacement LCD screen? I'm looking for one for my CTK-573 keyboard mbuseck1@yahoo.com
mbuseck1 - Reply Share
Hi. Would this screen work for CTK 481?
José Saldaña - Reply Share
hi. I have the ctk 4300. i would like to know where i can get one.Binitintimo@gmail.com
timo binitin - Reply Share
Past 24 Hours: 0
Past 7 Days: 14
Past 30 Days: 98
All Time: 6,066
