Up to 20% off select tools
Casio CTK-501 Battery Connection Replacement
Views: 6K
View statistics:
Past 24 Hours:
7
Past 7 Days:
22
Past 30 Days:
106
All Time:
6,012
Comments: 1
1 comment on steps.
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 40 minutes - 1 hour
Difficulty: Moderate
Missing Steps
Oops! This guide is currently missing one or more important steps.
Tools
Introduction
Go to step 1 ↓
This guide will walk you through the battery connection replacement process for the Casio CTK-501.
The circuit board collects all the power from the keyboard. If the battery area has been damaged, repair to the connection circuit board may be needed. This repair may be needed if the device will not turn on after cleaning the battery area and replacing the batteries.
Soldering knowledge is needed. If you are unfamiliar with soldering, take a look at this soldering guide for more information.
Use caution while soldering not to burn yourself or your surroundings.
    1. Casio CTK-501 Battery Connection Replacement, Bottom Panel: step 1, image 1 of 2 Casio CTK-501 Battery Connection Replacement, Bottom Panel: step 1, image 2 of 2
      • Flip the keyboard over so that the bottom is facing up.
      • Remove the twenty-seven 12 mm screws from the dark-grey panel using a Phillips #2 screwdriver.
      Ask FixBot
    2. Casio CTK-501 Battery Connection Replacement: step 2, image 1 of 1
      • Remove the bottom panel by lifting and pulling it towards yourself.
      Ask FixBot
    3. Casio CTK-501 Battery Connection Replacement: step 3, image 1 of 2 Casio CTK-501 Battery Connection Replacement: step 3, image 2 of 2
      • Flip open the top half of the keyboard.
      • Set the keyboard onto the bottom half with the internal parts facing up.
      • Be careful not to let the bottom drop.
      Ask FixBot
    1. Casio CTK-501 Battery Connection Replacement, Battery Connection: step 4, image 1 of 1
      • Plug in the soldering iron.
      • Set the soldering iron somewhere safe, where it can't catch anything on fire.
      • Unscrew the top green circuit board with black and red wires running through it.
      Ask FixBot
    2. Casio CTK-501 Battery Connection Replacement: step 5, image 1 of 1
      • Set the circuit board somewhere flat so it is safe to solder.
      Ask FixBot
    3. Casio CTK-501 Battery Connection Replacement: step 6, image 1 of 1
      • Heat up the solder covering the end of the wires connected to the circuit board.
      • Once the solder melts, remove the wires from the circuit board.
      Ask FixBot
    4. Casio CTK-501 Battery Connection Replacement: step 7, image 1 of 1
      • Melt new solder with your soldering iron.
      • Then apply it over the tip of the wire resting on the circuit board.
      Ask FixBot
    5. Casio CTK-501 Battery Connection Replacement: step 8, image 1 of 1
      • Once the wires are firmly attached, screw the circuit board back into the keyboard.
      Ask FixBot
3 other people completed this guide.
Author
with
Jimmy Winne
578 Reputation
6 Guides authored
Cal Poly, Team 9-16, Amido Fall 2012 Member of Cal Poly, Team 9-16, Amido Fall 2012
CPSU-AMIDO-F12S9G16
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 22
Past 30 Days: 106
All Time: 6,012
