Casio CTK-3200 Speaker Replacement
    1. Casio CTK-3200 Speaker Replacement, Center Front Panel: step 1, image 1 of 2 Casio CTK-3200 Speaker Replacement, Center Front Panel: step 1, image 2 of 2
      • Remove the seven 10 mm Phillips #1 screws on the underside of the keyboard that secure the center front panel.
      Ask FixBot
    2. Casio CTK-3200 Speaker Replacement: step 2, image 1 of 1
      • Flip the keyboard over and remove the central panel on the front and place it above the keyboard.
      • Make sure not to sever or strain any connections between the yellow-colored main board and the central panel.
      • If the panel is not easily removable, make sure all the screws are removed from the back.
      Ask FixBot
    1. Casio CTK-3200 Speaker Replacement, Side Panel: step 3, image 1 of 2 Casio CTK-3200 Speaker Replacement, Side Panel: step 3, image 2 of 2
      • Remove all eight 10 mm Phillips #1 screws that secure the side panels.
      Ask FixBot
    2. Casio CTK-3200 Speaker Replacement: step 4, image 1 of 1
      • Carefully remove one side panel at a time from the top of the keyboard and place it above the keyboard, making sure not to sever any connections between the yellow-colored mainboard and the side panels.
      • If the panels are not easily removable, make sure all the screws are removed from the back.
      Ask FixBot
    1. Casio CTK-3200 Speaker Replacement, Speaker: step 5, image 1 of 2 Casio CTK-3200 Speaker Replacement, Speaker: step 5, image 2 of 2
      • Carefully remove the four 10 mm Phillips #1 screws that secure the speaker.
      Ask FixBot
    2. Casio CTK-3200 Speaker Replacement: step 6, image 1 of 1
      • In order to replace the speaker, desolder the wire at the two locations indicated in the photo.
      • To install the the new speaker, you will solder the same wires to the marked locations.
      • In order to safely and correctly solder the new wire, please refer to the soldering guide.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Connor Bentley
219 Reputation
2 Guides authored
Cuesta, Team 10-4, Krynen Fall 2024 Member of Cuesta, Team 10-4, Krynen Fall 2024
CUESTA-KRYNEN-F24S10G4
4 Members
24 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 31
All Time: 370
