Tools
Introduction
Go to step 1 ↓If your Casio CTK keyboard (model 3200) has keys that are sticking, not working, or broken, use this guide to replace them.
The keys are the plastic material that you press on to make the sounds. The keys are pressed and they register that motion by applying pressure down on a button below them.
It makes noise by relaying that signal through the main board, transmitting the press to the speakers which create the sound for that specific key. If any part of the key is broken, you may experience it not making noise or just sitting flat. If that is the case you will have to replace it.
Remove the seven 10 mm Phillips #1 screws on the underside of the keyboard that secure the center front panel.
Target which key(s) need to be replaced and unscrew the 10 mm Phillips #1 screws for the targeted section(s).
There are five different sections of white keys, you can tell the sections apart by the small gaps between them where the screws are attached.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
