Casio A1000 Battery Replacement
    1. Casio A1000 Battery Replacement, Battery: step 1, image 1 of 2 Casio A1000 Battery Replacement, Battery: step 1, image 2 of 2
      • Press down on the spring with your index finger to detach the wristband.
      Ask FixBot
    2. Casio A1000 Battery Replacement: step 2, image 1 of 2 Casio A1000 Battery Replacement: step 2, image 2 of 2
      • Use a Phillips #000 screwdriver to remove the four screws from the back side of the watch.
      • Keep your parts in one place so that you do not lose them.
      Ask FixBot
    3. Casio A1000 Battery Replacement: step 3, image 1 of 2 Casio A1000 Battery Replacement: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • Carefully remove the sticker that covers the battery with tweezers.
      • Be careful of your fingers because the ends of the tweezers are sharp.
      Ask FixBot
    4. Casio A1000 Battery Replacement: step 4, image 1 of 3 Casio A1000 Battery Replacement: step 4, image 2 of 3 Casio A1000 Battery Replacement: step 4, image 3 of 3
      • Unhook the lever that holds the battery with tweezers.
      • Carefully remove the dead battery.
      Ask FixBot
    5. Casio A1000 Battery Replacement: step 5, image 1 of 2 Casio A1000 Battery Replacement: step 5, image 2 of 2
      • Insert the new battery into the watch and engage the lever.
      • With your tweezers, reset the AC battery by contacting both the (+) and (AC) points at the same time
      Ask FixBot
    6. Casio A1000 Battery Replacement: step 6, image 1 of 1
      • To reset the watch time:
      • Press the bottom left button to switch mode.
      • Press the bottom right button to reset the number to zero and adjust time.
      • Press the top left button to switch between the hour, minute, and second hand.
      Ask FixBot
Thank you for following our simple guide to replacing your Casio A1000 watch battery. We hope that you will be able to use your watch again!
2 other people completed this guide.
Steven Trinh
181 Reputation
1 Guide authored
UC Davis, Team 3-4, Andersen Winter 2023 Member of UC Davis, Team 3-4, Andersen Winter 2023
UCD-ANDERSEN-W23S3G4
3 Members
12 Guides authored
2 Guide Comments
Thank you. This helped convince my son to purchase a Casio A1000 instead of more expensive alternative; the other, as I pointed out, would involve battery replacement that would be more involved, require tools probably not available to him in his location, and likely end up being beyond his pay grade regardless. Casio, on the other hand, allows the KISS method. Much better bang for the buck here. You're the Man!
LongLostAlaskan - Reply Share
Great. Can you write about what number screws are in this Casio? I can't find it anywhere and I lost 2 and need to buy some more. Unfortunately I don't know what exactly to look for. I will be very grateful for information.
Remigiusz Kurtz - Reply Share
Past 24 Hours: 4
Past 7 Days: 49
Past 30 Days: 182
All Time: 3,872
