Casdon Dyson Ball Disassembly
Views: 17K
View statistics:
Past 24 Hours:
10
Past 7 Days:
52
Past 30 Days:
196
All Time:
16,904
Comments: 8
2 comments on steps, 6 guide comments.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Using a PH00 screwdriver, this guide will demonstrate how to disassemble the Casdon Dyson Ball. This disassembly will show how to separate the battery compartment from the vacuum ball.
Tools
    1. Casdon Dyson Ball Disassembly, Battery: step 1, image 1 of 1
      • Remove one 9.2mm (0.36 in) screw using the PH00 screwdriver.
      • Remove the battery cover by pulling it away from the vacuum once the 9.2mm (0.36 in) screw is removed.
      Ask FixBot
    2. Casdon Dyson Ball Disassembly: step 2, image 1 of 1
      • Remove batteries from the vacuum by pulling them out and away from the vacuum.
      Ask FixBot
    1. Casdon Dyson Ball Disassembly, Casdon Dyson Ball Disassembly: step 3, image 1 of 1
      • Remove all seven 9.2mm (0.32 in) screws on the back of the vacuum.
      Ask FixBot
    2. Casdon Dyson Ball Disassembly: step 4, image 1 of 1
      • Remove the front side covers by pulling them away from the vacuum.
      Ask FixBot
    3. Casdon Dyson Ball Disassembly: step 5, image 1 of 1
      • Separate the battery compartment from the ball and bead cylinder by sliding the vacuum ball away from the battery compartment.
      Ask FixBot
    4. Casdon Dyson Ball Disassembly: step 6, image 1 of 1
      • Separate the bead cylinder and the fan compartment by pulling the bead cylinder away from the fan compartment.
      Ask FixBot
    5. Casdon Dyson Ball Disassembly: step 7, image 1 of 1
      • Remove beads from the container.
      Ask FixBot
2 other people completed this guide.
Seldon Price
612 Reputation
5 Guides authored
IUPUI, Team S3-G5, Harley Fall 2017 Member of IUPUI, Team S3-G5, Harley Fall 2017
IUPUI-HARLEY-F17S3G5
3 Members
60 Guides authored
6 Guide Comments
How do I get the handle out once assembled?
Carie McClendon - Reply Share
Den Griff bekommt man nach dem Einstecken offensichtlich nicht mehr entfernt.
Das Batteriefach bietet keinen Zugang um die Befestigungsraste zu lösen.
Fraglich ob man an die Befestigungsraste kommt, wenn man das Gerät quasi komplett auseinanderschraubt.
Bei eBay wird ein gebrauchtes Gerät angeboten, bei dem der Griff nicht mehr hält, der Besitzer hat vermutlich versucht den Griff mit Gewallt herauszuziehen und dabei die Befestigungsraste abgebrochen.
Das Gerät lässt sich mit dem nicht mehr entfernbaren Griff nicht mehr im Originalkarton verpacken und versenden.
In meinen Augen eine mangelhafte Konstruktion.
"Wie bekomme ich den Griff nach der Montage heraus?"
NichtCheck - Reply Share
How does the handle come out in English what language was that? There is no videos on how to remove the handle or even get the little pellets to spin again
steven welch - Reply Share
The fan to make the beads jump around no longer works….is there. Separate battery for that?
Kathy - Reply Share
Nein, der "Ventilator" für die Perlen wird mit den Batterien betrieben.
Ich würde davon ausgehen, dass der Ventilator bei Ihnen defekt ist, sofern er nicht unwahrscheinlicher Weise durch eingeklemmte Perlen blockiert ist.
Past 24 Hours: 10
Past 7 Days: 52
Past 30 Days: 196
All Time: 16,904
